Active handling system light
Old Mar 5, 2013 | 04:10 PM
99supercharged's Avatar
99supercharged
Default Active handling system light
I have a 1999 frc and sometimes it throws a code that states active handling system failure and the car display reads "engine powering down," and the car is limited in top speed. The car has 25,000mi on it, I did change the front tires to 275/45/18 and rear to 305/35/18. I called caspers electronics about the rtd simulators and they were unsure if that would fix it. My car does have original factory shocks on it, all I have done is tires, rear control arm bushings, and tranny diff brace. Any help would be much appreciated.
Old Mar 5, 2013 | 04:28 PM
99supercharged
Originally Posted by 8VETTE7
Excellent chance that your choice of tire sizes is the cause of your AH/TC problem
General rule of thumb is that the rear tires need to be between 1/2" and 1 1/2" larger in overall diameter than your front tires.
Your rear tires are about 26.3" tall while your front tires are 27.7" tall. You need a front tire that is about 25.5" tall if you want to keep the rear tire size.
In a word you have it a$$ backwards..........
You need a front tire that is about 25.8" or less tall if you want to keep your rear tire size.
So is there anything I can do to fix this besides buying new tires? Can I use a programmer to tell the car what tire size I have to fix the issue? Can a dealer do this for me? Thanks so much
Old Mar 5, 2013 | 04:52 PM
99supercharged
What tire size would you reccommend?
Old Mar 5, 2013 | 04:54 PM
99supercharged
I am going to need new rear drag radials soon. Should I just go with a taller rear? I see nitto makes a 305/45/18
Old Mar 5, 2013 | 05:15 PM
jamieo's Avatar
jamieo
That would give you a little over 1" difference,so it should take care of the active handling code.
Old Mar 5, 2013 | 05:20 PM
99supercharged
Thanks very much for your time. Im glad to know the problem now.
To Active handling system light
