Cam install, complete.
Old Jun 17, 2002 | 01:13 AM
C5Noir's Avatar
C5Noir
Default Cam install, complete.
Shew, that's one heck of a job for jack stands and a parking lot ;). Being my first time ever doing anything like this I feel it went pretty smoothly despite the two snags I encountered, removing the steering rack and the crank pulley. That steering rack is one **** of a unit to remove. I must personally thank Andy@AAcorvettes and 9D9LS1 for all of their help and tips on removing the steering rack. I also must personally thank torquecentral.com, 66ImpalaLT1 and jMx for all the help they have been in guiding the cam install process. Also, I thank my brother, 2000_ws6 and Go FasTA (fellow C5 owner/member/friend) for their help with the install. I couldn't have done it w/out them :cheers:
Now, we put in:
ASP Pulley
ARE Blueprinted/Ported Oil Pump
Katech (JWIS) Timing Chain
TR 224.2/224.3 .563/.563 111.9 (Thanks to the Cam Doctor)
Comp Cam 918 Springs :yesnod:
Comp Cam Titanium Retainers
Crane Cam Chromemoly Pushrods
Now, how does it sound/drive/run?
Well, I must say I was a little leary about firing her up the first time to do the first heat cycle. It fired right up and found its idle and loped like a ****. It sounds sooooooooo nice. It's tame yet mean (no cats on the car ;)). If I had the cats on you'd barely notice it. Inside the car very little shake which will be alleviated after I bump up the idle to around 825 and get my TB hole correct. Also, my new oil pump bumped my idle oil pressure to 41 PSI :eek: from 21 PSI with the stock oil pump! After the second heat cycle for the springs I hopped in and took it for a run....
It PULLLLLLLLLLLLLLLLLSSSSSSSSSSSSSSSSSSSSS SSSSSSSS beyond comprehension. I haven't even loaded the LS1Edit file to raise the rev limiter to 6700. I can't wait to spin it up that high ;). This cam flat out rocks. It's so sweet to sit at a light with your ride going, "lumpity lump lump". Very intimidating to others :D It's running pig rich ( I can smell the gas) so now I'm going into hardcore LS1Edit tuning ;) then off to the wideband O2 to get the AFR correct and then it's dyno time :D :D :D
Here's just a sample of how sweet she sounds: http://home.insightbb.com/~ominousvette/camlope.mpg
If anyone has some webspace let me know so I can post some more vids ;) and lots of pics I took during the install. Thanks to Paul and the rest of Thunder Racing for hooking me up with a sweet cam. They're a tuner that has definately done their homework on the camshaft selection for LS1 cars!
First, TR 224 powered C5 :yesnod:
[Modified by C5Noir, 12:40 AM 6/17/2002]
Old Jun 17, 2002 | 01:27 AM
Go FasTA's Avatar
Go FasTA
Default Re: Cam install, complete. (C5Noir)
I've got web space you can use. Just let me know and I'll get the stuff up there for you.
Old Jun 17, 2002 | 01:33 AM
ScreaminDemon's Avatar
ScreaminDemon
Congrats! My motors apart and I guess I'm behind you, but not for long!! :cheers:
Old Jun 17, 2002 | 04:11 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
:cheers:
Congrats, self satisfaction has been accomplshed!
Old Jun 17, 2002 | 05:08 AM
NassyVette's Avatar
NassyVette
Default Re: Cam install, complete. (wallstAL)
:cheers:
Congrats :cheers:
Old Jun 17, 2002 | 08:07 AM
Scott97's Avatar
Scott97
Default Re: Cam install, complete. (NassyVette)
:cheers: :cheers:
Old Jun 17, 2002 | 08:42 AM
AllCammedUp's Avatar
AllCammedUp
Man Levi, that mpg kicks bootie! Congrats on what I'm sure was a challenging, yet rewarding, job! You guys are to be commended!
Old Jun 17, 2002 | 09:25 AM
vstella's Avatar
vstella
Sounds great! .......I know how your feelin' ...it just gets better! :yesnod:
Old Jun 17, 2002 | 10:13 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Congrats! Excellent choice! :cheers:
Um... Don't think so. :nonod:
Old Jun 17, 2002 | 10:33 AM
Da Kind's Avatar
Da Kind
Sounds bad aSSSSSS!!
Old Jun 17, 2002 | 11:10 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Cam install, complete. (Da Kind)
:cheers: Love the sound :yesnod:
Old Jun 17, 2002 | 12:07 PM
Miles in Michigan's Avatar
Miles in Michigan
Congratulations!
How long did it take? Did you need any special tools? Crank puller I suppose, but I don't know what else. Is there a good online cam install document somewhere? I've seen one for f-bodies, but not for C5s.
What part of the install requires more than one person? No one I know is into cars, and it's too late to ask my parents for a brother. :eek:
Now, we put in:
ASP Pulley
That's *exactly* what I want to put in my car. I cheaped out on the headers (ordering RK Sport for $699, instead of FLP), but other than that, you've got the car I want. :)
Are you going to dyno any time soon?
Old Jun 17, 2002 | 12:08 PM
pkmoose's Avatar
pkmoose
Default Re: Cam install, complete. (Mag Red Monster)
:cheers: :cheers: :cheers: :cheers:
Old Jun 17, 2002 | 12:25 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Re: Cam install, complete. (pkmoose)
Welcome to the "Thunder Cam Corvette Club" - can't wait to see the dyno!
Old Jun 17, 2002 | 01:24 PM
C5Noir's Avatar
C5Noir
Default Re: Cam install, complete. (Miles in Michigan)
It took two days, almost 14 hours. You will need a crank puller (will get you the model # when I get hom) and a valve spring compressor (will get you that model # too...). Other than that you need a various assortment of sockets, ratchets, etc. Also you'll need to rent a 250 ft-lb torque wrench from Autozone to seat the crank pulley all the way. I used http://www.torquecentral.com for the cam install (the cars are identical after you remove the power steering rack).
Really it can all be done by yourself. It just helps to have others around to help speed it up. 66Impala_LT1 put his cam, etc in all by himself. Check out http://www.ls1tech.com and go to the Corvette Performance section and check out his post about his cam install. It's very informative.
Yes, I plan on going after I get my part throttle LTRIM's set so that I can then go and tune it WOT (PE vs RPM) on the dyno ;)
Oliver, thanks for the welcoming! BTW, what is your idle currently set at? Thanks.
Old Jun 17, 2002 | 01:29 PM
OliverM5's Avatar
OliverM5
My idle is set at the stock idle (725-750 or so) - I never had to drill out the TB or do any tuning with the cam..........
Old Jun 17, 2002 | 01:36 PM
RED99HT's Avatar
RED99HT
How hard was it to change the valve springs while the heads were still on the car? Anything special you need to do?
To Cam install, complete.
Old Jun 17, 2002 | 02:34 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Cam install, complete. (RED99HT)
Awesome job man!! It is a good feeling isnt it when you organize a big mod project, do the whole install yourself, and then things work out awesome. The power feels all that much better when you took part in the install and part selections.
I am sure in no time you will have LS1edit all figured out and your car tuned perfectly! Just make sure to get your LTRIMS slightly in the negative, then work on your WOT a/f on a dyno with a wide band.
:cheers: :cheers:
Old Jun 17, 2002 | 03:00 PM
motoracer's Avatar
motoracer
:cheers:
Old Jun 17, 2002 | 03:12 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: Cam install, complete. (Buckmaster)
Congrats man, sounds like you have made an excellent selection in that bad **** C5 of yours!. Must be nice to be able to do major mods yourself! :cheers:
You should be pulling some great power with your set up after getting your fine tuning done.
Good luck and be safe!
Nitrovette :cheers:
