GM Crate engine/LS3
Old Mar 9, 2013 | 10:15 PM
bontrager's Avatar
bontrager
Default GM Crate engine/LS3
Hello everyone.
I am considering adding this GM LS3 engine to my 2000 vert (480 HP).
http://www.jegs.com/
Item #'s 809-19258768K and 809-19258768 without controller
My engine has only 19,500 miles on it and is in great condition; what would this engine be worth to the installer?
You will notice there are two versions listed on this link. One includes a new controller(??) and wiring harness, etc for an additional 1200.00.
Is this version necessary or can I just go with the complete engine and use the corresponding parts from the LS1.
I prefer normal aspiration instead of Supercharging or TT.
Please advise, Thank you.
Last edited by bontrager; Mar 9, 2013 at 10:22 PM. Reason: won't accept complete link
Old Mar 10, 2013 | 03:59 AM
C5Enthusiast's Avatar
C5Enthusiast
I'm pretty sure the stock LS1 controller parts (maf, ecm etc) won't work with the LS3. The
link describes what's included. Hopefully someone who's done the conversion before will chime in..
Old Mar 10, 2013 | 08:55 AM
AU N EGL's Avatar
AU N EGL
2000 LS1 worth about $1500 if that.
there is a LS1 converter that can go on the LS3 engine
Old Mar 10, 2013 | 11:48 AM
10.5Vette's Avatar
10.5Vette
Your LS1 PCM will work, but will obviously have to be reprogrammed for the new engine. You will need this for converting the 58x signal to the 24x signal: http://www.lingenfelter.com/mm5/merc...3#.UTVbvRzrzRE
Here is the page to some adaptor harnesses. youll need map sensor harness, injectors, cam extension, mass air if you change to a card type or zo6 mass air, throttle body harness, and knock sensor extension,
http://www.speartech.com/category_s/1826.htm
You will need to use an LS2 silver blade throttle body.
Old Mar 10, 2013 | 02:36 PM
bontrager's Avatar
bontrager
Thank everyone for their responses.
As I view a picture of this engine it looks to be complete therefore I don't understand the need for injectors, cam extension,throttle body, knock sensor entension ( thought the knock sensors were under the manifold).
Did you get a chance to look at in on the Jegs.com website?
Thank you.
Please excuse my ignorance
Old Mar 10, 2013 | 02:47 PM
10.5Vette's Avatar
10.5Vette
The connectors don't match up with the ones in your harness. Some are different, some are too short.
Yes, I've seen the Jegs website. I'm thinking about doing the same swap myself. I get a pretty good discount from Jegs advertised prices since I've been doing business with them so long.
Old Mar 10, 2013 | 04:40 PM
WKMCD's Avatar
WKMCD
You MAY need to replace the TB with one from an LS2. People have been having trouble tuning the LS3 TB on the the C5.
Old Mar 11, 2013 | 08:44 AM
bontrager's Avatar
bontrager
Once again, thanx to all. Starting to get expensive aad don't even have a quote on the labor install or a quailified shop to do the install and tuning.
See to be pushing $10,000 with all the extra parts needed.
May have to pass. I was just looking for more low end torgue. Would changing the gear ratio to 390 give me what I want (6 speed manual)?
Thank you.
Old Mar 11, 2013 | 10:13 AM
WKMCD's Avatar
WKMCD
$10k is probably a pretty good number for something like this.
I ran 3.90's in my 346 build and have always said "These cars should have come with 3.90's". It puts every gear in a more usable place and the seat of the pants kick is excellent.
I even got a wild hair and had Rick Kim put 3.90's in my 427.
Old Mar 11, 2013 | 10:22 AM
10.5Vette's Avatar
10.5Vette
I was looking at coming in way under 10K for this. But I'm going to do all the work myself. To me that's part of the fun.
To GM Crate engine/LS3
