Help with C1277 code!!
Old Mar 10, 2013 | 10:46 PM
thepitstop2010's Avatar
thepitstop2010
Default Help with C1277 code!!
My 2000 sets a C1277 code every time I place the car in gear and begin moving. Requested torque signal malfunction is the code description. I have ran a continuity check on the wiring between the EBCM and ECM. Everything tested ok. My question is do I have a ECM or EBCM problem? I know of the common issues with the EBCM's failing but don't think this code is one of the sh*t out of luck codes with a bad EBCM. Hope someone can point me in the right direction.
