clutch master question
Old Mar 12, 2013 | 07:21 PM
Dave_2003_TRZ06's Avatar
Dave_2003_TRZ06
I am on the NW side of town (cy-fair) if you feel like making the trip North. If you do go it alone, get some gear wrenches (13mm) for the clutch pedal assembly, makes it a little easier.
Old Mar 12, 2013 | 07:22 PM
Dave_2003_TRZ06
Originally Posted by zeevette
Now that I see pictures, you may be right about removing the panel. I've done so many mods, and scraped so many knuckles; I must be getting memory selective.
I hear yah!
Old Mar 12, 2013 | 07:46 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Your master should be to you in a few days, thanks for the order.
Old Mar 12, 2013 | 08:05 PM
chuckie669's Avatar
chuckie669
always a pleasure dealing with you.
Old Mar 15, 2013 | 05:19 PM
chuckie669's Avatar
chuckie669
well... wish me luck. just got the part in, super fast btw.
Got the car jacked up and supported wheel and liner out. now just trying to find all the stuff in the lousy pdf provided from tick. What's the connection your supposed to remove in 2? guessing its the wires below the clutch line to help ease removal. Also haven't figured out best way to remove hydraulic line. I see a quick dissconnect or screwdriver, but just looks like a rounded hose.
I'm a tard sometimes.
Old Mar 15, 2013 | 05:37 PM
Dave_2003_TRZ06
I think I used a 17 or 19mm open wrench to disconnect the master hydraulic line from the slave connection/line. There is a plastic piece on the MC line that needs to be pushed into the slave coupler to unlock the lines. I used on open wrench as 'disconnect tool' to push that piece in.
Old Mar 15, 2013 | 05:40 PM
Dave_2003_TRZ06
FWIW...I used this PDF
http://www.supertuneperformance.net/...structions.pdf
Old Mar 15, 2013 | 06:04 PM
chuckie669's Avatar
chuckie669
fantastic!
Old Mar 15, 2013 | 06:56 PM
chuckie669's Avatar
chuckie669
i must be missing something. looks like the plastic should just push in. i've pressed, tried using a wrench but guess i may not be pushing enough of it in at once to cause the release?
should it just pop off? tried switching to a screwdriver but worried I'm going to damage it.
edit: got it. ended up making my own tool with a dremel and one of those wrenches you get putting furniture together. always wondered why I kept those around.
Old Mar 15, 2013 | 10:37 PM
Dave_2003_TRZ06
adapt and overcome
Old Mar 16, 2013 | 08:00 PM
chuckie669's Avatar
chuckie669
worked on this off and on today. got the new clutch master installed to the pedal.
Question, looks like the shipped setup is still shorter than the lowest point of the clutch pedal depressed so it can't be installed. How much did you adjust the rod? I tried to evenly open the top and bottom side of the rod to install, but not sure how much clutch pedal I should be expecting (right now its none).
Old Mar 17, 2013 | 01:32 PM
Dave_2003_TRZ06
If I recall correctly, had to let quite a bit of that rod out. I did this at both ends as well. If you want I will take a pic under my dash today, so you can have a frame of reference.
Old Mar 17, 2013 | 02:16 PM
  #33
bumble-z's Avatar
bumble-z
For those wondering how to disconect/reconnect the Quick Disconnect.
Using these tools.
Long nose vice grips, disconnect/reconnect tool. Size (5/8")Auto Zone.
TOOLS
DISCONNECT SIDE OF TOOL
PUSH IN ON PLASTIC (TOP HAT)
CONNECTING SIDE OF TOOL
TOOL PUSHING ON STEEL (BALL) OF QUICK DISCONNECT
https://www.corvetteforum.com/forums...ditor/bold.gif
Old Mar 17, 2013 | 02:21 PM
  #34
chuckie669's Avatar
chuckie669
that would be great
Old Mar 17, 2013 | 02:27 PM
  #35
chuckie669's Avatar
chuckie669
Thanks for the tips. hopefully it will help someone out. I had a buddy come by with some of those to help, but apparently there was no lip on my white plastic piece. Good news is the new slave line Does have a nice one.
got it all put back together (I hope). Really not a lot of pedal movement for the clutch at its current setting. Taking a break, just had a good time learning about hydraulics and how to gravity bleed by myself in the garage. Got it to the point of a steady slow stream for about 30 sec and think I'm done.
After a quick bite, I guess its time to reconnect the slave hose and all the connectors and see what I got.
2 main issues were the clutch pedal 13mm bolts SUCK putting back in. I was praying to baby jesus, budah and anyone else who would listen to get a thread on those things. Not going to share who won.
the other was I tried to cut the stock firewall boot and it just doesn't fit well around the white plastic cap. I got it placed around 80% of the unit and guess its just going to stay like that.
I appreciate all the help guys!
Old Mar 17, 2013 | 10:00 PM
  #36
chuckie669's Avatar
chuckie669
big thanks to Dave 03 z06. got it all done and took her for a drive. looks like it's all setup tho the rod needs to be shortened back some.
amazing how much stiffer the new mc is from the stocker. a little stiffer than oem without the assist spring.
at this time looks like there's about three inches from the floor up to where the pedal starts to engage and one inch after that to full release. hopefully shortening the rod will help with that.
