Prop shaft assembly balancing
Old Mar 12, 2013 | 06:03 PM
Zo39's Avatar
Zo39
Navigator
Default Prop shaft assembly balancing
I need to find a shop that can high speed (6500 redline) balance a 2001 Zo6 prop shaft assembly. This is a custom-extended shaft that was built for a 39 coupe project. I have called all the shops that were listed in a Google search without any luck. Thanks for your time
Old Mar 12, 2013 | 06:15 PM
zeevette's Avatar
zeevette
Didn't the manufacturer balance it?
Old Mar 12, 2013 | 08:52 PM
Zo39's Avatar
Zo39
Navigator
I am the manufacturer
Old Mar 12, 2013 | 11:01 PM
PhysicsDude55's Avatar
PhysicsDude55
They're not in your neck of the woods, but I think if any shop can do what you need, its these guys:
http://www.carolinadriveline.com/
They're well respected in the offroad community for custom built and performance extended offroad driveshafts that can also be street driven.
Old Mar 13, 2013 | 12:57 PM
corvettebob1's Avatar
corvettebob1
I used to use Joint Clutch & Gear in Detroit on Telegraph just south of Joy Rd. when I lived up in Mi.
They would make any kind of propshaft you wanted and did balancing for any driveline part.
Old Mar 13, 2013 | 08:32 PM
Zo39's Avatar
Zo39
Navigator
I called Carolinadriveline today and they are going to high speed balance it. Thanks for your help.
To Prop shaft assembly balancing
