? about LS1 engine
Old Jun 17, 2002 | 05:33 PM
Bollox's Avatar
Bollox
Default ? about LS1 engine
Has anyone heard of a hotcam which is supposed to be the same cam used in the LS6 and i've been told it will take the LS1 up to 405hp is this correct or bs. Can anyone tell me what I should be paying for a new LS1 engine. Any help appreciated.
Old Jun 17, 2002 | 05:41 PM
Sam Lin's Avatar
Sam Lin
Default Re: ? about LS1 engine (Bollox)
GM Performance Parts catalog has a "Hot cam" for the LS1 engine. I can't help you with the other stuff, sorry.
Sam
Old Jun 17, 2002 | 05:45 PM
Mitch C's Avatar
Mitch C
Default Re: ? about LS1 engine (Sam Lin)
The Hotcam is not the same cam used in the LS6. It will give you more performance than the stock LS1 cam but you will not get 405 HP with just a switch to the GM Hot Cam. :nonod:
Old Jun 17, 2002 | 05:46 PM
Bollox's Avatar
Bollox
Thanks for the reply. My mechanics found the LS1 engine from gmperformance with the hotcam installed but gm can't provide actual figures stating that the engine puts out 405hp it is just their estimate from the specs of the cam which i hope someone here can tell me if it close, correct, or way off. I need to know because I can't spend so much on a egine just by taking their guesstimates on hp rating. By the way this engine is going in a 91 Z28 if anyones interested. :D Thanks for any help if anyone knows it will be someone here on corvetteforum.
Old Jun 17, 2002 | 05:52 PM
Bollox's Avatar
Bollox
about what kind of increase will the hotcam provide? and what else would I need to take it up to real close to 400hp?
To ? about LS1 engine
