Transmission Leak
Old Mar 14, 2013 | 05:22 PM
CyborgX_CZ's Avatar
CyborgX_CZ
Default Transmission Leak
Can anybody tells me what needs to be resealed or fixed to stop this type of leak? Thanks -R
Old Mar 15, 2013 | 09:46 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Without a tear down, trying to guess would be a crap shoot.
Old Mar 15, 2013 | 10:51 AM
CyborgX_CZ's Avatar
CyborgX_CZ
Why do I have to tear down transmission? I thought maybe someone can pin point what is leaking. Maybe it is the reverse solenoid or skip shift solenoid or vent tube I thought someone run in to the same problem before.
Old Mar 15, 2013 | 01:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like the vent tube to me. Its not dripping out of a specific point.
Clean it up and make sure that the reverse solenoid and housing are properly torqued.
Have you thought about making the differential better?? Check out these post:
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
Old Mar 15, 2013 | 01:27 PM
CyborgX_CZ's Avatar
CyborgX_CZ
Thanks for your input these are amazing threads for future re-built but in my case I just need to re-seal everything since this come out of 04 Z06, I will check those solenoids and maybe I will buy new went tube just in case.
Old Mar 15, 2013 | 03:34 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Recommendation:
Just to insure that you dont put a damaged rear in your car.. Slip the output shafts in the rear and see how much force it takes to hold one hub and turn the other. A brand new rear will take approx 100ft/lbs+ to over come the friction disks.
If one or both of your clutch pack Beleview springs are broken, it will be really easy to over come the clutch friction disks.
Bill
Old Mar 15, 2013 | 03:44 PM
alextz's Avatar
alextz
The Bellevue washers in the diff tend to become cracked (especially if the car gets lots of wheel hop through lots of drag launches). The bellevue washers hold the clutch packs together. there are two of them.
Old Mar 15, 2013 | 04:16 PM
CyborgX_CZ's Avatar
CyborgX_CZ
Thanks guys, I will check everything before I put it back. It came out of our track car which got caged this winter and since everything was out we decide to fix these leaks. Thanks aging for all inputs on this.
Old Mar 15, 2013 | 04:37 PM
SaberD's Avatar
SaberD
just so everyone knows, they are called belleville washers lol. I don't know how many silly names I've seen for these things lol.
Old Mar 16, 2013 | 12:50 PM
Quicksilver Vert 01
I'm still recommending a tear down and inspection. You probably don't need to go as far as removing the tranny or diff gears, but a thorough inspection of the internals, along with a fresh set of gaskets and seals, would be wise investment at this time.
Basically you could do it now, or do it later along with the additional R&I labor.
Old Mar 16, 2013 | 01:17 PM
CyborgX_CZ's Avatar
CyborgX_CZ
I will do what I can. I guess this will be the best time to do it anyway :-)
Old Mar 16, 2013 | 01:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats just one of those words that,, no matter how many times that I see it spelled correctly, I butcher it when I use it again
To Transmission Leak
