I bought four new rotors and I started to put them on today and on the first wheel I started on (right rear) the bottom bolt on the caliper bracket is not wanting to come out, anyone had this same issue? Thought about pulling out the heat and trying to warm it up to see if that would work. Any words of advice are welcomed.
If by " heat", you are meaning a butane torch, you should be ok.
There is red loc tite on those threads.
Along with red loc tite & the more than 100 lb ft, makes them very hard to break loose.
I suggest, if you are going to be doing that type of work on your car to purchase a premium impact gun to go along with an air compressor.
Makes short work of breaking such bolts loose..an easy task. (with out the use of heat)
Sorry, I did mean a butane torch not a cutting torch or anything like that, I am using my impact and it still would budge, so I'll try that and see if I'm successful. Thanks for your reply.
I used brute force, a breaker bar and six point socket and about 5' of pipe
Adding some heat on the bolts from a propane torch would have helped but I used elbow grease and a long extension (5' of pipe over the breaker bar) to crack the 125 ft lb locktited bolts loose. Bent the breaker bar in the process. When I reinstalled the bolts first cleaned the bolt threads of old locktite, then added new red locktite and retorqued to 125 ft lbs. This straightened out the breaker bar.
A LOT OF FUN
A LOT OF FUN
I snapped three sockets and two socket wrenches (all Craftsman) while trying to break mine loose with a five foot breaker bar. It finally took me holding the third replacement wrench and fourth socket with a breaker while a buddy pounded on the breaker with a sledge hammer, and this was after soaking the bolt with about 1/4 can of PB overnight. Those back bolts are more fun than a slinky on an escalator...
IIRC, GM doesn't recommend reusing those caliper bolts. I think it recommends replacing them. With the amount of torque that is put upon them, they must stretch somewhat.
there were a total of 2 of these bolts in over 20 GM dealships in Wash DC area
Looks like nobody replaces those bolts.
Mine still good after 15 years.
If you want to pay the vette tax I am sure your dealer will supply them to you.
The maximum torque those 15mm bolts can see without yielding should be around 150 ft-lbs. GM only recommends replacing those because they come with loc-tite pre-applied.
Since I track my car I go through alot of rotors. I've had mine on and off well over a dozen times. No problem using the bolts over again and I use Locktite blue.
I thought it was insane advice when I'd heard it - but it worked:
Once you're securely on jackstands - put your wrench + breaker on the bolt. Put your jack under neath the lever of the wrench / Breaker bar. Jack it up.
It'll flex, then crack the nut loose.
I use an old shade tree trick. I go to the grocery store and in the spice rack I get a bottle of pepermint oil. I put a few drops of that on really tight bolts and the next day they come right off. YOu still have to put 125 lbs of torque on the bolt, nut, whatever to get it off though.
I got mine loose by putting and impact driver socket (six sides vs 12 for regular socket) on a 1/2 drive ratchet wrench (12 inch), and banging on the wrench handle with a small sledge hammer.
I'm glad I saw this post...I just changed mine a week ago and when i took those bolts out i did it with a Boxed end Hand wrench with no problem and then installed them back in with the same....So i need to get under there and retighten them i didnt know about the 125# torque...or If im breaking loose bolts with locktight and 125# torque with just my hand....well then i need to get laid!
