Going to replace reverse gear, what seals will I need?
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
You will need the large O ring that goes between the differential and the transmission.
According to the service manual, you just need anerobic sealer between the case halves.
Im attempting to provide you the T-56 repair manual on PDF by attaching it to the post. If i fail, PM me your e-mail adderss, and ask for it and I will send it:
"WTF,, thats for an F body,,,
"Yep ,, it is and other than the end covers, the rest is pretty much the same.
If you want the real procedure, you will need the service manuals.
You stated, when you split the motor from the trans,,,
Hmmmm,,,the trans and the differential are in the rear and connected to the engine via torque tube..
C5 T-56 MN12 Version with internal TRANSILLA T-60-60 upgrade
BC
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Bill, I definitely intended to say split trans from diff, not motor. My bad. I wasn't sure if there's a seal that goes there or not, but apparently there is an o-ring. Thanks a ton for putting up all that info, sorry I didn't thank you sooner!
C66, the left diff axle seal? Does it run forward when it leaks or something? Because it leaks where the trans and diff come together IIRC.
STEVE
Please explain this flip the reverse gear thing further???? Inquiring minds would like to know???????
Bill
Bill, the front of that couple inch long section gets sealed with goo and the part that mates to the diff gets an o-ring, right? Is there trans fluid sitting in the cavity between the diff and trans then or is that just a dust seal?
