hey guys im looking at buying a 02 vert here in a little bit and the heads up and climate control are not working. Is this a common problem? Easy fix or gonna cost me alot? thank you
If the HUD is not displaying at all, it is not easy to get to since it is not in a place to easily access. Not real expensive (in my opinion) to buy another one but unless you replace yourself it will be very expensive.
HVAC units (automatic dual zone units, not not manual units) normally have the LCD panel go dark but still work. If this is the case it is an easy fix I have done myself. Many people here can fix the unit for about $50. Not too hard to access even if you are not a do it yourself kind of person. Let us know if we can help further. When I bought my 2001 I deducted $500 off the price for this issue. I fixed it for zero dollars and a little solder and electricity for the soldering iron.
PS: I find searching the Forum is better if you use Goggle. You will get not only this Forum but info from other locations. Could be just me, but others have said the same thing.
