Clutch upgrade questions
Old Mar 21, 2013 | 01:53 PM
BBA's Avatar
BBA
Default Clutch upgrade questions
If I wanted to put a C6 Z06 (LS7) style clutch in a C5 LS1 (2004), what parts directly bolt in or do we have to get adaptors for anything?
Old Mar 22, 2013 | 08:12 AM
BBA's Avatar
BBA
So far all I can tell is using the stock LS7 clutch means you might need a shim/spacer on the slave cylinder so the pedal isn't too low.
Is that it?
Old Mar 22, 2013 | 12:05 PM
feeder82's Avatar
feeder82
didnt need shims flywheel, pressure plate and disk, direct bolt in
Old Mar 22, 2013 | 02:52 PM
BBA's Avatar
BBA
What pedal position do you have when you engage/disengage the clutch?
I know if there is too much space between the slave piston and throwout bearing the pedal will travel almost to the floor before the clutch releases/engages, and too little space the engagement will happen closer to the top of pedal travel (which is actually worse for clutch life as the pedal moves up as the clutch wears normally).
Old Mar 23, 2013 | 10:28 AM
feeder82's Avatar
feeder82
Mine operates the same as the stock clutch did.it engages right in the middle of pedal travel
Old Mar 25, 2013 | 10:30 AM
BBA's Avatar
BBA
Thanks for the information.
To Clutch upgrade questions
