Battery volt reading
Old Mar 25, 2013 | 04:50 PM
Kramterrab's Avatar
Kramterrab
Default Battery volt reading
When turning the key from OFF to ON the gauges do their sweep and then go to their respective values. When I watched battery voltage today it slowly ramped up to just under 13 volts. I mean slowly. This is a new fresh charged battery. Then when I cranked the starter it pulled the voltage down to approximately 8 to 10 volts. Today after battery installation it clicked once then fired right up. First time it happened. Usually pops right off. I'm using a standard 5/16 short combo wrench to tighten the cables. Maybe I'll see if I can torque the posts to 8ft/lbs which is what the battery manufacture specifies. What are you seeing on your in car voltmeter when turning to ON fast or slow meter ramp up?
Old Mar 26, 2013 | 11:28 AM
TEXHAWK0's Avatar
TEXHAWK0
My display shows voltage immediately, but does read .5 volts lower than at battery terminals... I would make sure grounds and all connections are tight...
Have you tried reading the actual voltage across the terminals?
Old Mar 26, 2013 | 11:34 AM
Gordy M's Avatar
Gordy M
Your battery needs 12.5V or more to start and control all the electronics correctly. Remove the battery cables and using a VOM measure the voltage at the battery. You can charge you battery but once you remove the unit you are to the base voltage. Less that 12.5V and you encounter hard starting, the dreaded column lock problem, and other gremlins. I pushed my OEM battery too many years and even with the CLB installed still enabled the column lock-fuel cut off problem.
Old Mar 26, 2013 | 11:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The DIC Digital Volt meter and the analog voltage gage do NOT read actual battery voltage. They read the battery voltage after it goes thru the IGNITION SWITCH!
Your ignition switch has 5 main contacts inside and those 5 contacts can get carboned and burnt. The resistance caused by the damaged contacts is what you are seeing.
Here is a detailed post that explains it all and how to fix it:
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
If the switch contacts get bad enough, it can affect proper module operation, fuel pump output and cause all kinds of weird DTCs to set.
Bill
Old Mar 26, 2013 | 06:44 PM
Kramterrab's Avatar
Kramterrab
A voltage drop across dirty contacts is normal. I'm not concerned with that. I read 12.72 across the battery measured with a calibrated Fluke 87. The battery is one month old and fully charged before install. I'm going to look at the connections bat+ to fuse box, bat+ to starter. Plus I'll torque the posts to the manufacture specified torque. If I can get my 1/4" torque wrench in there.
Ps. This is a great forum. People like Bill and others spent a lot of time with these cars. Much appreciated. This is my first C5. Got a C4 to.
To Battery volt reading
