Skid plate install help
Old Apr 2, 2013 | 12:26 AM
Fastlsvette's Avatar
Fastlsvette
Default Skid plate install help
I oredered my skid plate but I was reading and it says you need some kind of bolts or special tool to install??
Old Apr 2, 2013 | 12:52 AM
The Void's Avatar
The Void
I believe you are referring to the riv-nuts or nut-serts. It is not a tool. It is an insert with threads (like a nut.. go figure) that creates anchor points on the skid cage. You then have threaded attachment points to connect the air pump/ middle air dam / maybe the horns?
There are also four riv-nuts in the frame that allow you to connect the skid cage. They are used extensively around the frame to connect other things as well - like the head lights.
When I replaced my cage they were already installed. All I had to do was powder coat it. There is nothing to it though to install them. Depends on where you got your cage from on this point though. GL.
Old Apr 2, 2013 | 10:07 AM
Fastlsvette
I got it on ebay and yes thats exactly what im referring too, we will see when it arrives
Old May 31, 2013 | 04:55 PM
YeeeeeHaw's Avatar
YeeeeeHaw
Default nutserts installation
Does yours come with the nutserts installed? Mine doesn't.
Did you have to install yours and how?
Old May 31, 2013 | 08:11 PM
maxx2200's Avatar
maxx2200
Mine didn't come with the nut-serts. I oredered them from GMPartshouse or Corvette Central but I'm sure you could get them at a dealership if you were in a hurry.
To Skid plate install help
