Front turn signal lamp
Old Apr 2, 2013 | 02:00 PM
WI84's Avatar
WI84
Cruise-In XII Veteran
Wounded Warrior Escort '11
Default Front turn signal lamp
Just wondering if anyone can tell me how to replace my right front turn sgnal lamp on my '98. The book says to remove the front facia closeout panel, but I don't know what or where that is. Thanks.
Old Apr 2, 2013 | 02:37 PM
Vettmann17's Avatar
Vettmann17
Very simple, watch the video.
Old Apr 2, 2013 | 02:50 PM
MG RED 99's Avatar
MG RED 99
Here's a link to the closeout panel and procedure.
http://www.justanswer.com/chevy/1i3n...er-s-side.html
Old Apr 2, 2013 | 03:00 PM
WI84's Avatar
WI84
Thanks for the help. I tried it, but only got the audio. No video.
Old Apr 2, 2013 | 03:15 PM
WI84's Avatar
WI84
Hey Vettman,
Tried a different computer and got the audio AND video. Thanks for the help. I think I can do it now.
Old Apr 2, 2013 | 03:24 PM
runner140*'s Avatar
runner140*
One of three ways....1. Thru the brake ducts. 2. Thru the bottom inspection panels. 3. Thru the headlights.
Simple three minute job.
Old Apr 2, 2013 | 03:45 PM
WI84's Avatar
WI84
I don't know. I can get atb the socket all right, but I can't get it to turn. Is there some kind of release on the socket? That paying the Chevy dealer $60 to do is starting to sound better.
Old Apr 2, 2013 | 04:04 PM
Vettmann17's Avatar
Vettmann17
Originally Posted by WI84
Hey Vettman,
My pleasure, glad I could help.
Old Apr 2, 2013 | 04:10 PM
Vettmann17's Avatar
Vettmann17
Yes, at one end of the socket there is a clip that you have to push in to get it to turn, kind of a lock to prevent it from getting loose. You can feel it once you get your fingers on it. Once you get your fingers on it just keep feeling around the socket, you'll get it.
Old Apr 2, 2013 | 04:19 PM
WI84's Avatar
WI84
I'm about ready to give up on it. 2+ hours and I'm not much farther along than when I started.
Old Apr 2, 2013 | 04:30 PM
MG RED 99's Avatar
MG RED 99
Did you not see my post above? It's simple just raise the front of the car a bit. Either use a jack or drive up on some boards. Trying to do it through the brake duct is a pain. Going from below will allow you to see what you are doing as well.
Old Apr 2, 2013 | 04:41 PM
Vettmann17's Avatar
Vettmann17
Don't give up, you can do it!
Old Apr 2, 2013 | 06:03 PM
WI84's Avatar
WI84
After 3 1/2 hours, I finally got the socket out. Now all I have to do is figure out how it goes back in. I suspect that may take another 3 1/2 hours. FYI. I watched that video and the guy said to get it out turn it clockwise. Come to find out, it's COUNTER clockwise.
Old Apr 2, 2013 | 06:45 PM
WI84's Avatar
WI84
I finally got it. Only 4 1/2 hours to do a 3-10 minute job.
Old Apr 3, 2013 | 02:04 AM
kabluie's Avatar
kabluie
Which method did you use?
Old Apr 3, 2013 | 07:39 AM
runner140*'s Avatar
runner140*
Sorry I said is a simple job...three minutes. I use the headlight method.
Think I've done it three times now.(the same light...right side)
Old Apr 3, 2013 | 07:57 AM
WI84's Avatar
WI84
I found a picture of the socket on-line so I knew where the catch was. I took the plastic cover around the headlight off and could get right at it. Found the catch, pushed it in and the turned it COUNTER clockwise instead of clockwise like the guy said in the video. It came right out. Then I pulled the socket out through the opening for the brake duct and replaced the lamp. Had a little problem getting the socket in the right position to get it back in, but I got it. I'm sure the next time will be a WHOLE lt easier. Much thanks for everybody's help.
To Front turn signal lamp
Old Apr 3, 2013 | 10:14 AM
Vettmann17's Avatar
Vettmann17
Glad to hear you finally got it. The first time is always a bitch, but at least now you know. Glad we could help.
Old Apr 3, 2013 | 11:22 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
We need to see your scars now!
Old Apr 4, 2013 | 03:48 PM
TEXHAWK0's Avatar
TEXHAWK0
You can also reach the bulb from the topside, by opening the hood and reaching down along the frame, but for those that don't really want to tear up your arms, just remove the access panel behind the spoiler and you can see and remove it easily...
I found that I can remove the access panel just about as fast as trying to do it the "easy way".
