Pulling out of gear problems
Old Apr 4, 2013 | 02:41 PM
Quickshift_C5's Avatar
Quickshift_C5
Default Pulling out of gear problems
Car is a 2001 ZO6 with Vortech V3 SI and 46k miles. Using the OEM transmission. Clutch is a McLeod RST with 7kmiles. Supercharger has been installed just as long. Car sees a lot of Autocross, and a little drag racing.
In the past couple months, I've noticed that its requiring more effort to change gears. It doesn't really seem to matter what gear you're going from, but its requiring a light tug now to get it out of gear. No other issues other than that. I fear I'm seeing the start of some serious problems with the trans.
What do you guys think?
Old Apr 4, 2013 | 03:04 PM
tlove32's Avatar
tlove32
1 - Stock shifter or aftermarket?
2 - When was the last time you changed the trans fluid?
Old Apr 4, 2013 | 03:10 PM
Quickshift_C5
Stock shifter, and have never worked on it or removed the boot.
I have never changed the fluid beyond the "Ranger Method" of cleaning the fluid from the reservoir. I think the shop I had install the supercharger may have changed the fluid. I don't know this for sure, but I will ask.
Old Apr 4, 2013 | 03:15 PM
3sACROWD's Avatar
3sACROWD
The Ranger method is for the clutch fluid. The question was about the last time you changed the transmission fluid. (you have to get under the car to do it.)
Being that you auto-cross the car, your shifter may not be aligned properly anymore. I would try a shifter alingment first as you complain about every gear being an issue. The process is simple and takes 30 minutes if you've never done it before. Search shifter alignment and you should be able to find the procedure.
Old Apr 4, 2013 | 03:19 PM
Quickshift_C5
Ah right..clutch fluid.
I'll check out the shifter alignment first thing when I get the car back. Why would Autocross bring the shifter out of alignment?
To Pulling out of gear problems
