Shock Replacement NEED HELP!!!
Old Apr 8, 2013 | 12:10 PM
BryanB83's Avatar
BryanB83
Default Shock Replacement NEED HELP!!!
Need to replace the shocks on the 1998; it has the selective ride shocks which I would like to change out.
Has anyone had this done in the Austin, TX area? Removing shocks, deleting selective ride codes(tech II tool) and installing standard shocks. I know the process just can find anyone that has done this before.....
I dont want to use simulators!
What shop/person did this for you?
Old Apr 8, 2013 | 12:41 PM
Trog's Avatar
Trog
Any shop with access to a Tech II can do it... easy enough... Perhaps HP Tuners as well but not sure about that...
Old Apr 8, 2013 | 12:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to access the programming in the BCM.. Its actually an RPO Code that needs to be deselected. As trog stated It requires use of the TECH2. Any shop or person with a TECH 2 can do it.
NO,,, HP Tuners or EFI Live can not interface with the BCM. You must use the TECH 2. You also have to disconnect the ride control computer in the rear hatch well and NEVER reconnect it again! If you do, it will revive the Selective Ride crap!
Heres a post for you to examine:
-C5, Disable the F45 option using Tech2 VODA1, http://forums.corvetteforum.com/c5-t...ing-tech2.html
This is the actual post that shows you the actual screen shots in the tech 2:
http://www.stopforce.com/RPO.html
Bill
Old Apr 8, 2013 | 07:12 PM
JanMan99's Avatar
JanMan99
thanks everybody for your important input.......will take your advice....
To Shock Replacement NEED HELP!!!
