HVAC knob stuck on 69 degrees
Old Apr 8, 2013 | 08:19 PM
corvettedaddy11's Avatar
corvettedaddy11
Default HVAC **** stuck on 69 degrees
ok 98 vette, tried to turn the ac down to 60 degrees and its stuck on 69 LOL go figure .So whats the problem can it be fixed or do I have to buy another unit LOL..!
Old Apr 8, 2013 | 10:35 PM
dreww's Avatar
dreww
Check outside air temp sensor. On passenger front under scrape guard
Old Apr 8, 2013 | 10:38 PM
corvettedaddy11
what does it look like ? nevermind I see it ill replace it first.
Old Apr 8, 2013 | 10:43 PM
corvettedaddy11
Thanks Dreww
Old Apr 8, 2013 | 10:47 PM
BigGun's Avatar
BigGun
There are people on e bay who can fix some problems. They usually fix the dim display stuff but i think they also do other repairs. Just search C5 dim display and you will get several hits.
Check and see if you have any hvac codes. Here's a link that describes how to pull the dic codes. http://www.stengel.net/diccodes.htm
Old Apr 8, 2013 | 10:51 PM
BigGun's Avatar
BigGun
That doesn't have anything to do with adjusting the cabin temp.
Old Apr 9, 2013 | 11:09 PM
TEXHAWK0's Avatar
TEXHAWK0
If the set temperature will not change, you probably need a rebuilt AC control head... There are places that specialize in rebuilding and upgrading the control units...
One is Digital-Dash-Solutions
Old Apr 9, 2013 | 11:18 PM
corvettedaddy11
Ill check them.
Old Apr 10, 2013 | 11:32 AM
rwlc5's Avatar
rwlc5
Mine could only be changed a degree or two. Had to get a rebuilt unit. I may have gotten it from Digital Dash.
To HVAC knob stuck on 69 degrees
