oil sensor replace?
Old Apr 9, 2013 | 03:13 AM
04blackice's Avatar
04blackice
Default oil sensor replace?
So my oil sensor might be leaking. How much work is it to remove intake? And where do i het that relocation kit I've been hearing about? And is there anything i can or should do while intake is off? Like hoses or sensors to be replaced. Thanks
Old Apr 9, 2013 | 08:01 AM
bracketshark's Avatar
bracketshark
I didn't take my intake off to replace the OP sensor, nor did I cut anything. It can be done, the hardest part was disconnecting the wiring clip. 45 minutes tops, I've not pulled my intake (yet, but soon) I've read it can be removed / installed maybe even quicker.
Old Apr 9, 2013 | 08:02 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
check the DIY sticky thread at the top of this page
Old Apr 9, 2013 | 11:27 AM
dblerman's Avatar
dblerman
Pull the intake. You don't have to remove it completely from the car, just move it forward a few inches to get enough room to access the sensor. You won't have to disconnect the fuel line either. I can have my intake moved to access the sensor in about 7-10 minutes, and completely out of the car in less than 15.
So many times I read threads about people who try to do it without moving the intake and they say it took them forever because of the lack of room.
Old Apr 9, 2013 | 11:53 AM
williamb81's Avatar
williamb81
Mights on a dogs ***, lol
I would reach your hand back there and feel around to see if thats where it is leaking from.(lots of other places it could be) Part is 40 bucks to replace and you need a 1 1/16 socket. I made a custom wrench for my camaro oil sending unit that works great. GL and let us know what you find....
Old Apr 9, 2013 | 11:58 AM
04blackice's Avatar
04blackice
Oh i forgot to say i replaced it once without removing intake. And it took me an embarrassing 4-5 hrs even with the help of my neighbor's fancy tools. I thought maybe other way would e easier..can you do the mod also that way??
Old Apr 9, 2013 | 02:17 PM
3boystoys's Avatar
3boystoys
Well, if you have the intake OFF, you can seal the knock sensor well to keep water out and install the relocation kit easier too. Less than 4-5 hours with one hand!
Old Apr 9, 2013 | 03:10 PM
maxx2200's Avatar
maxx2200
http://www.dpecorvettes.com/gpage7.html
This is the one I used with no complaints.
Old Apr 9, 2013 | 07:16 PM
04blackice's Avatar
04blackice
Nice. So if you run the gage style doea is still have the electrical part that you plug in. Or does using the gauge eliminate it. Maybe a dumb ?
Old Apr 9, 2013 | 08:14 PM
b_rad!'s Avatar
b_rad!
I just received my parts from Summit for the relocation because I am putting on a Fast 92 and LS2 VMax TB and I figured this would be the time. Here is a list of the parts you will need.
ATM-2268 ADAPTER METRIC
$10.95
EAR-64191914ERL -4 ST./ST. 14 HOSE
$17.95
EAR-9894DBJERL FEMALE 16MM X 1.5
$8.95
SUM-220121 -6 TO -4 ADAPTER
$6.95
SUM-220455 -04X1/4 45 NPT-AN
$6.95
Total aprox $52
Old Apr 9, 2013 | 08:32 PM
04blackice's Avatar
04blackice
U
$10.95
$17.95
$8.95
$6.95
$6.95
Total aprox $52
thats awesome thanks. Let me know how it goes. If anything else is needed after the fact.. thanks again
Old Apr 9, 2013 | 08:37 PM
vectorz's Avatar
vectorz
I don't see any sticky
To oil sensor replace?
