Installed Vortex Today. Have questions
Old Jun 19, 2002 | 09:20 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Installed Vortex Today. Have questions
I installed my vortex today and seems to have a better throttle response than before. So thats a Good thing.
My question is the rubber foam that is included was wider when installed than my creavce in the shroud. It caused the vortex when screwed down to have a small gap in each top corner. Has anyone had this happen. I took a small amount of caulk to the gap and sealed it. Doesnt look bad but was wondering why this might have happen.
I had a blackwing before and I am noticing a difference in response. Do I have to do an idle relearn or just drive it for a while and will it get stronger down the road?
Thanks :seeya
Old Jun 19, 2002 | 10:47 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Installed Vortex Today. Have questions (golfman)
All the Vortex systems sold and no response. :crazy:
Old Jun 20, 2002 | 12:39 AM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Installed Vortex Today. Have questions (Buckmaster)
No the foam was taller than the crevice. so the vortex didnt have a totally flat surface to lay on. There is no bolts in the top corners so it had a little gap there.
I hope I have explained this right. :)
Old Jun 20, 2002 | 02:21 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Mine was a little off, so I had to cut and tuck in a little foam in some areas. I got a strong SOP feeling and did not do any relearn procedure. Just drive it and the PCM will adjust.
Old Jun 20, 2002 | 09:21 PM
golfman's Avatar
golfman
St. Jude Donor '05
Default Re: Installed Vortex Today. Have questions (wallstAL)
Your right mine is awesome. There is a deference between this and the blackwing no doubt. I know alot of people like the blackwing and I had one to but it doesnt compare to this not even close guys. :smash:
Old Jun 20, 2002 | 09:51 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
:yesnod: :D
To Installed Vortex Today. Have questions
