It’s that time of year to get your corvettes out and start driving, but more importunately you need to be able to stop if you’re on the fence about new brake pads maybe we can help you out. Carbotech Performance Brakes, the world leader in Ceramic friction materials. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry that means our pads will not harm your wheels or paint on your vehicle. Please contact me with questions or to place an order.
Yes, the 1521 compound for street use is a low dusting ceramic based pad that does not give up braking performance for the street. Give me a call at 216-780-8825 I will be happy to help you out.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes™ are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
do you offer options for other vehicles as well? i'm getting close on my 05 dd escalade to needing rotors and pads. truck sees mild towing (2,500 lb boat several times a year) and people hauling..mostly just me in it tho. i would like something coated on the rotors to avoid rust, as i have nice rims on the car that have wide openings between the spokes. can you pm me some options? i also LOVE that you're semi local, i'm near toledo! for great lakes brewery!
to the brewery. I will pm you pricing for the 1521 compound. We do not sell rotors.
Carbotech brakes utilize a ceramic and metallic construction in a range of compounds that out-perform competitive brakes. Carbotech brakes are made from compounds that offer higher initial bite, torque and fade resistance—providing consistent brake modulation and performance over a wide range of operating temperatures.
In addition, Carbotech brakes are rotor friendly, saving money and keeping your vehicle out of the service shop far longer than the competition.
Carbotech brakes give you:
• Assured stopping power
• Increased overall performance and handling
•Excellent modulation and release characteristics
•Better control entering the corners
•Longer brake pad and rotor life—up to four times longer than the competition!
•Longer rotor life
•Non-corrosive dust
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application. Contact info is below if you need some help or would like to order a set. Orders place direct through me receive 5% forum discount.
