oil filter wrenches
Old Jun 19, 2002 | 11:14 PM
canuckz's Avatar
canuckz
Default oil filter wrenches
Which oil filter wrench do you prefer?I am ready to do my first oil change and want to know what wrenches work best for removing the pf44.I will be using upf 44's from now on so will the same wrench work on this filter or will I need a different one?
Old Jun 20, 2002 | 12:08 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: oil filter wrenches (Buckmaster)
Don't know the name of it but all auto parts stores sell them. It fits onto the socket wrench and it fits the end of the filter perfectly. They are usually black powdercoated. Easiest one to use.
I use the same type, mine is a #2 Super Graphite by Flotool.
Old Jun 20, 2002 | 02:56 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: oil filter wrenches (wallstAL)
Ditto. I just checked mine and it has no name or size on it but you can just check it on the filter at the parts store. They work great.
Old Jun 20, 2002 | 11:45 AM
NEED FOR SPEED's Avatar
NEED FOR SPEED
CI 3-4-5-6-7-8-9-10 Vet
St. Jude Donor '07
Default Re: oil filter wrenches (FunDriver)
The filters are different. I have AC-Delco filter wrenches. Take the UPF-44 with you to be sure it fits. You could borrow a PF-44 in stock to compare. Some aftermarket wrenches may fit both. Good luck. :seeya
Old Jun 20, 2002 | 12:39 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: oil filter wrenches (NEED FOR SPEED)
I use a strap wrench. In 10 years I've never found a filter I couldn't remove.
It even gets the over tightened ones.
It is the best one out there :yesnod: IMHO
To oil filter wrenches
