What Trans fluid do you use?
Old Apr 14, 2013 | 09:20 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Default What Trans fluid do you use?
I am going to be changing my trans fluid this week and want to know what you guys use?
My car is NOT STOCK, 700hp and an RPM Level 6 Trans with a 3200 Yank!
I drive my car on weekends only and when I do drive it, I'm not very gentile with it.
What are the top trans fluids for extreme, hard driving?
Old Apr 14, 2013 | 04:01 PM
Navy Blue 210's Avatar
Navy Blue 210
Default Trans Fluid
check out 3 options from Amsoil and discuss with your builder
1 Super Shift Synthetic Racing Fluid product code ART
THIS IS A TYPE F fluid which can handle the heat but is Very Grabby
Your tranny will last longer (less slippage & wear)
I have 2 clients using very happy 383vett norcal forum
Low 10 sec bracket car and 1200 horse 1400 torque
4wd dodge diesel high 8 sec.
2 Torque Drive product code ATD this is Heavy Duty Anti Shear
Dex 3 type fluid that would handle the heat for the stall and the
Power no problem not as Grabby.
3 Universal ATF product code ATF another dex 3 compatible fluid
That would work as well
