Shift solenoid issue?
Old Apr 16, 2013 | 10:30 AM
NotAnExpert's Avatar
NotAnExpert
St. Jude Donor '13
Default Shift solenoid issue?
I have an '02 base with an A4 and I am wondering if the issue I am exeriencing has something to do with the 1-2 solenoid.
When I begin to accelerate in first gear at a mild pace I feel a bite of a bump when it shifts to 2nd. When it goes to third it does so more smoothly; and the same is true for the shift to 4th.
Now when I WOT beginning in first or second it will hang and bump the rev limiter for about 1-1.5 secs then hard shift into the next higher gear. The shift from 3rd to 4th at WOT does kick a little but it feels like its a clean shift.
Could this be the 1-2 solenoid? If not, what is the likeliest reason for this experience?
Old Apr 16, 2013 | 06:34 PM
Vic'sVette's Avatar
Vic'sVette
I'm no expert mechanic--even less a tranny mechanic, but...
How many miles are on the car?
Have you done a filter/fluid change?
Mine (at ~94k) did the 'double bump' thing, too--however, not near as bad as what you are describing--mine did not hit the rev limiter. I had my mechanic do a filter/fluid change and replaced a & b shift solenoids and the pressure control solenoid. This took care of the double bump for me. I don't know if it was the fluid change or the shift solenoid but my guess is it was the solenoid.
Good luck.
Old Apr 17, 2013 | 10:52 AM
77BlueL82's Avatar
77BlueL82
Default Lock up
I had the same problem and replaced the lock up solenoid and the problem was solved.
To Shift solenoid issue?
