c5r chain on stock gears
Old Apr 16, 2013 | 06:16 PM
rcrflyby's Avatar
rcrflyby
Default c5r chain on stock gears
Im trying to decide which chain/ gears to go with for my 01 z06 cam swap. Ive been reading that the ls2 chains have alot of slack on the stock gears but i was wondering if anyone has used the c5r chain on the stock ls6 gears. My last resort is this http://texas-speed.com/p-3930-cloyes...-bolt-cam.aspx but its a little more than i want to pay. I guess you get what you pay for though. Thanks
Old Apr 16, 2013 | 07:09 PM
vettenuts's Avatar
vettenuts
I did on my first cam installation. Motor is an LS1 but there is no difference between the 02 LS1 and LS6 timing sets.
Here is prior to the damper installation
Here is after the damper is installed
Old Apr 16, 2013 | 07:18 PM
WKMCD's Avatar
WKMCD
I run a Cloyes adjustable timing set. More $$ but it is a very nice setup.
FWIW: There were some offshore imports being sold as C5R timing chains a while ago so be careful and get it from someone like Katech.
Old Apr 16, 2013 | 07:49 PM
rcrflyby's Avatar
rcrflyby
Vettenuts is that the c5r chain that's pictured?
Yea I would most likely buy the chain from katech
Old Apr 17, 2013 | 03:01 AM
rcrflyby's Avatar
rcrflyby
i just bit the bullet and bought this set http://www.coloradospeed.com/cloyes-...2-p-20505.html Im tired of worrying about it lol.
Old Apr 17, 2013 | 04:42 AM
vettenuts's Avatar
vettenuts
Yes, that is the C5R chain from Katech. As stated above, there were some knock offs being sold. Also, be aware, IWIS makes several chains of varying quality and the same pitch. If you buy the C5R make sure you know what you are getting.
On my current setup I went with a Cloyes Hex-Adjust with the IRL (Indy Racing Legue) chain. This was the best single chain ever produced for the LS1 and it was hand made. I would have to pull my notes on it but as I recall it was blueprinted and shot peened as well. The IRL chain was originally developed for the Olds Aurora motor being run in the Indy cars. Cloyes stopped making this chain several years ago because the Katech C5R chain was less money and the LS2 chain had come out. They had a bunch on the shelf unsold in their warehouse and SDPC bought them all about three years ago. They are hard to find buy may still be available.
Old Apr 17, 2013 | 04:14 PM
rcrflyby's Avatar
rcrflyby
hopefully this setup is worth the money cause it damn sure was expensive!
Old Apr 17, 2013 | 04:38 PM
WKMCD's Avatar
WKMCD
Shawn Miller is one of the leading engine builders around. He built my Darton Sleeved LS2 block 427 and used the best internals. He chose the Cloyes Hex Adjust timing set for the build.
That's good enough for me.
Old Apr 17, 2013 | 05:30 PM
zeevette's Avatar
zeevette
I'm cheap. When I did my first cam swap, I just used the stock gearset, and a LS2 chain. Years later, there's been no issues with my timing set. If I remember, it was $28.
Old Apr 18, 2013 | 07:42 AM
rcrflyby's Avatar
rcrflyby
thanks guys
To c5r chain on stock gears
