C5 Spark Plug Removable ?
Old Apr 20, 2013 | 11:08 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Default C5 Spark Plug Removable ?
99 6MM coupe. Original Owner.140,000 miles. All stock. Non raced. 2nd set of AC Iridium plugs have 68,000 miles on them. I did not apply any lub of any kind to the threads. Car runs great. Considering new plug installation. I have heard that there may be a problem in getting them out due to " welding " ,carbon etc. What if any problems, if any have any of you great guys had.
Your experiences please.
The Big Guy !
Old Apr 20, 2013 | 11:20 AM
reath1's Avatar
reath1
Just changed mine out at around 57K. Only problem I had was getting the boots off. Literally destroyed everyone of them so you should plan on changing wires also. Didn't look like there was any anti-seize used on the originals. Zero problems getting them out. The new ones got a healthy dose of Never-Seize and both ends of the boots also got a healthy dose of di-electric grease. If you grease the boots make sure they click on good and re-check them several times within a week or so to make sure none backed off on you.
Old Apr 20, 2013 | 11:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The engine should be dead iron cold when you remove them. A new set of GM Performance Red Wires will make you happy. They fit and look excellent, Contact Gene Culley www.gmpartshouse.com for a complete set $62.
A little bit of anti seize on the new plugs will help in future maintenance. Always use Dielectric Grease on the wire boots.
Bill
Old Apr 20, 2013 | 12:22 PM
tacman's Avatar
tacman
St. Jude Donor '13
Default Wires
Bill
Bill,
GM wires OK with headers?
Old Apr 20, 2013 | 12:49 PM
newbs49's Avatar
newbs49
Your gonna need heat boots. DEI or whatever brand you like.
Old Apr 20, 2013 | 01:07 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive had headers and stock designed wires installed on my 02 since 2004. No heat or fitment issues what so ever. I use the C5 wires with the metal shields.
My Stainless Works Headers have 1 3/4" primaries. If your boots actually TOUCH the header, you will either need coolsox or a different designed plug wire boot. The C6 ZO6 wires have a 90 deg boot that may fit where the the stock C5 design may not. It all depends on your header tube design and routing.
NONE, if mine touch at all.
Bill
Old Apr 20, 2013 | 01:39 PM
baxsom's Avatar
baxsom
I have plain GMPP red wires on mine with TSP headers for 2 years now driven every day. No heat shields, socks, boots, or any other assorted footwear and no issues with the wires.
Old Apr 20, 2013 | 02:22 PM
The Big Guy
Thank you all for your suggestions. The boots have not been a problem as I have used a Lisle Adjustable Spark Plug Wire Puller #51750. It works like unbelievable. Further I might add that it has been 8 years since I replaced the plugs. No one has answered my ? regarding possible stripping the threads from the head upon pulling the plugs after a long interval of use. Your further thoughts,Please.
Old Apr 20, 2013 | 02:27 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by The Big Guy
.... Further I might add that it has been 8 years since I replaced the plugs. No one has answered my ? regarding possible stripping the threads from the head upon pulling the plugs after a long interval of use. Your further thoughts, Please.
I don't want to sound sarcastic, but in my opinion, there's no hard, set answer. You just have to carefully remove them, and as Bill has already said, make sure the car is COLD. My suggestion would be to get the car in a position that you can work on it, the night before, then start the job the next morning...
Old Apr 20, 2013 | 02:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive seen a few cases where the engine had 90+K miles on it and they had thread strip issues. Ive also see 90+K miles and they came out without issue. What difference does it make. The only way to find out is to remove them. There are a lot more success stories than failure stories.
You should be fine.
Old Apr 20, 2013 | 03:51 PM
bighank's Avatar
bighank
Default If you need to spray some PB Blaster on the cold plugs and wait a couple hours
Bill
Old Apr 20, 2013 | 04:34 PM
The Big Guy
My most sincere " Thanks " to all you great fellow Vette people. It seems that I should be OK to just use a little " Blaster " and proceed with reason and caution. Also include the addition of Anti Seize and Die Electric to complete the job. Thanks for the tip on where to purchase the wires.
Good Luck to all,
The Big Guy !
Old Apr 22, 2013 | 11:20 AM
JetMechZ16's Avatar
JetMechZ16
Since someone else brought up anti-sieze, what type is best? Copper based? nickel based? etc. I know there are different types, not sure if it makes any difference.
To C5 Spark Plug Removable ?
