Tick speedbleeder install
Old Apr 21, 2013 | 02:43 PM
danieloneil01's Avatar
danieloneil01
Default Tick speedbleeder install
Just got a tick speedbleeder. It's got a washer between the hose and the fitting. Is this washer supposed to be removed and installed on the other side of the fitting against the slave? Do I need to use anything on the threads on the fitting to the slave and hose?
Don't want to install it like it is and find out it's wrong after everything is bolted up.
Old Apr 21, 2013 | 05:37 PM
k24556's Avatar
k24556
you mean a remote bleeder for the clutch? Then, yes, the washer goes between the fitting and the slave. Try the fitting by hand first w/o the washer and make sure the fitting will thread all the way down. When you take the OEM bleeder fitting out the threads can gall and keep the new fitting from going all the way in. (happened to me, anyway)
Old Apr 21, 2013 | 07:48 PM
danieloneil01
Did you use any thread sealer on any of the threads?
Old Apr 22, 2013 | 12:30 PM
k24556's Avatar
k24556
no thread sealer, no teflon tape either, no loctite either. The second time, I chased the threads in the slave and put the fitting in. Then checked for leaks after re-assembling the quick disconnect. The quick disconnet needs to be properly coupled, or you may dead-head the master. Thedrive train has to be connected together to get the QD coupler together, so the only view for a leak is with the inspection cover removed.
Old Apr 22, 2013 | 02:05 PM
danieloneil01
To Tick speedbleeder install
