Climate control lights staying on.
Old May 26, 2013 | 12:54 AM
lionelhutz's Avatar
lionelhutz
Nice work supplying a test controller to sort out the issue. That seems to validate that the lighting power is controlled with an internal circuit that has failed. My guess would be a transistor that powers the lighting has failed shorted or the driving circuit for the transistor has failed keeping the transistor on.
Old May 16, 2022 | 12:51 AM
Starks88's Avatar
Starks88
1st Gear
Default Hi I know Im late to the game, but maybe it will help someone now
Originally Posted by mikeyrko
I just bought my first Vette it's a 01 Coupe.
I parked the car locked it and the lights on the climate control are staying on.
Is this normal?
Yes I'm very late answering this. But just to help anyone who's having this problem and save them the 16 hours of hair pulling, that was my Sunday . The lights for My 2001 C-5 Climate Control panel would come on slowly after the car was turned off and stay on to the point where it would kill the battery. After taking out the HVAC unit , taking it a apart reassembling. I found the lights stayed off on the HVAC unit till I put the dash back together, So I reversed the process till I found that when I unplugged the Active Handling / Ride control switch from the center console, the lights instantly turned off and have stayed off. I hope this helps
