Tail lights not working
Old Apr 26, 2013 | 12:12 PM
82CEFan's Avatar
82CEFan
Default Tail lights not working
I am new to C5's and have searched the forum and not found this exact issue.
My tail lights and dash lights do not work when the headlight switch is turned on. However everything works fine when the twilight setting is used.
any ideas would be appreciated.
Old Apr 26, 2013 | 12:58 PM
BigGun's Avatar
BigGun
If the twilight works then it is usually the stalk failing.
Old Apr 26, 2013 | 02:24 PM
slvr bulit's Avatar
slvr bulit
Yep, sounds like the turn signal lever is on its way out. I just replaced mine this winter.
Old Apr 27, 2013 | 12:06 AM
BigGun's Avatar
BigGun
This link shows how it is done. Not as hard as it looks.
http://forums.corvetteforum.com/c5-t...-a-how-to.html
Old Apr 27, 2013 | 01:52 AM
82CEFan's Avatar
82CEFan
Thanks for all the help. I will get into this and see if I can fix it myself as well
To Tail lights not working
