I believe traction control is my issue.. here is the problem.
I have a 99 FRC with a D1 supercharger. The car makes about 550whp. A couple weeks ago I layed into the throttle and the motor bogged down heavily. It felt like the ECU had put the car into limp mode to protect it or something along those lines. There was almost no power at all. I've taken it out a few more times to diagnose the problem and it feels the same in any gear when going 50%+ throttle. I'm not throwing codes - and the engine is not in REP mode.
I had the battery out of the car for a few weeks (was just using it as a backup for my boat). I took it out this AM hoping maybe a PMC reset would change something but i still get the same result.
Today though - i noticed the "traction control activated" message would pop up when i'm having this problem. I believe traction control is activating when it shouldn't. I can feel some vibration in the rear like it's applying the brakes too. (it also feels like it's cutting throttle & spark etc)
Is there a sensor that may have went bad to cause this problem?
With 550hp and laying into the throttle, are you sure you are not spinning the tires some?
What size tires do you have? If they don't have enough stagger front to rear or if it is very close, then very little tire slip might cause the TC to engage.
This ^^^^
Had the same problem after putting Z06 size 295's on the back with 275's on the front.
Sounds like it's working normal to me. I doubt it has a clue how to handle 550whp, so it does what it does. It was designed for more like 300whp.......
Why don't you just turn it off?
Ron
I agree!! When it BOGS,, look at the DIC and see if there are any messaged like Traction Control ACTIVE or Active Handling Active.
If you have ACTIVE HANDLING,,, PRESS and HOLD the TC Mode button for 10-12 sec, it will go into COMP MODE and that will allow you to spin the tires all you want and it will attempt to keep the car going in the direction that your telling to.
I have 450 RWHP and I infringe on the cars handling computer frequently! Sometimes I forget to set comp mode or just turn it off.
Note!!!! When you are in OFF mode,,, ALL the driving is on "YOU"
The back end LOVES to try to out run the front end on these cars!!!
Have you pulled the codes or are you expecting to see them just pop up in the DIC?
I pulled the codes last week before resting the PCM - i'll post them below in my next post.
The car has been running at this power level and unchanged for at least 1 year. The TC actually works really well @ 550whp. Maybe there is some confusion with my description of the problem. This situation occurs in any gear - i can hit it in 4th gear and it will still bog down and the traction control light will blink. It is 100% not tire spin. I've very familiar what that feels like. There is almost zero acceleration going on here.
When it bogs - traction control active does flash. I do not have active handling. Here is the interesting part - when i turn traction control OFF completely - it still feels the same. (of course the TC light doesn't flash this time - but it still bogs like it's restricted again)
Here are the codes. I hadn't noticed the TC light was blinking previous to looking at these codes the other week - so it makes more sense now that C1286 might be my issue.
I'd be more concerned about the C1255 which is an internal malfunction of the EBCM.
What codes have come back since you cleared them???
I would also pull them again after the symptoms appear but BEFORE you shut off the ignition.
I drove it to work this AM. I disconnect the harness to the EBCM for testing purposes - nothing changed. Then i plugged it back in and reset the codes.
I have a 25 minute commute - as i went along - the condition got worse. I could just barely keep it at traffic speed now - forget about full throttle acceleration. A noise developed that i could hear through the shifter (a rattle). It was pretty loud. When i push the clutch in... it goes away. So i'm assuming something blew up in my clutch.
Some codes came up during the drive after the reset (checked while car was still running).
C1286 code means that the SWPS is giving the EBTCM false steering wheel position sensor (SWPS) inputs and the accelorometors are telling the computer that the car is going straight and NOT responding to those false steering wheel inputs.
SO,,,,, The EBTCM is applying brakes trying to make the car go in the direction that the false steering wheel inputs are telling it to go.
Im surprised that you said disconnecting the EBTCM had on effect on the problem ??? ??? When you disconnect that module, the Brake Pressure Modulator Valve (BPMV ) defaults to normal non assisted braking.
If it were me, I would pull the EBTCM fuses until you can get the SWPS replaced.
You also have a P0300 which is a Random misfire. Could that be your loss of power???
BC
This is the first time the P0300 code has come up. I read somewhere that it could be triggered from a few things besides misfire like vibrations etc (which i'm experiencing) Not to rule out this code - but there is certainty something wrong in my clutch / drivetrain after this AM's drive. I'll see if i can make a quick video...
BC
I had to remove the steering rack to install the supercharger - so i have no doubt that the wheel could use a good rotation with the linkage disconnected to straighten that out. Oddly though - i've driven the car for a year with no issues so i'm not sure why that would act up now causing problems.
In a recent development - there is an uncomfortable amount of smoke coming from the oil fill. I guess it's time for a compression check.
Make sure that none are broken. Seen the smoke from the oil fill and broken springs on a couple other cars.
If you have an infared laser temp probe, measure the temperature of EACH cylinder intake manifold runner at the point close to where it meets the head.
If one runner is a LOT hotter than the others, the bad spring is on that intake valve.
i think that goes for all c5's. the traction control system pretty much sucks if you ask me. it cuts way too much throttle. Although it can be useful in the rain at highway speeds in case you start to hydroplane.
