Timing cover measurement needed
Old Apr 29, 2013 | 01:37 PM
bracketshark's Avatar
bracketshark
Default Timing cover measurement needed
Will someone with a removed timing cover measure the hole where the seal goes in for me. Please I'm fixing to make an alignment tool for centering the cover. The seal measures 2.845", there is some press to the fit so the housing measurement will be closer. Thanks
Old Apr 29, 2013 | 08:04 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi bracketshark,
We have one you might be interested in. We just made them. They will be on our website in the next day or two for $19.95.
Here is a video of how it works.
Christian
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Apr 29, 2013 | 09:21 PM
bracketshark
Yes sir I'll take one, I can't believe someone hasn't made these before now. You can use the balancer installer to push the seal in and not even use the hammer, especially useful in the car.
Old Apr 30, 2013 | 05:13 AM
vettenuts's Avatar
vettenuts
I like the fact you are not using the seal for alignment like the recommended appraoch on ls1howto.com
Have you used this with a motor that has the pan already in place, such as when you were doing a cam swap?
Old Apr 30, 2013 | 09:44 AM
bracketshark
Have you used this with a motor that has the pan already in place, such as when you were doing a cam swap?[/QUOTE]
Not yet, but it won't be long now.
Old Apr 30, 2013 | 10:28 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
nice tool
Old May 2, 2013 | 12:27 PM
bracketshark
Originally Posted by SacCityCorvette
Hi bracketshark,
SacCityCorvette LS1 2 3 6 7 timimg cover tool. - YouTube
Christian
Ordered mine last night.
Old May 2, 2013 | 06:03 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Looks like an excellent product at a reasonable price.
My suggestion to Sac City would be, cut a notch in the tool, to allow for cranks that have been pinned.
Old May 2, 2013 | 06:59 PM
SacCityCorvette
Supporting Vendor
Thanks for your input on improving our products, we appreciate it!
That's a good idea, but when you pull the harmonic balancer off doesn't the pin come off with it. Our test engine was pinned but it came off with the harmonic balancer.
Old May 2, 2013 | 08:10 PM
bracketshark
I don't think the pin will come out easy, if you use the ATI pin kit. I think I'm going to do both pin kits, ATI first then the one that pins from the front. I don't see where it can hurt anything.
Old May 3, 2013 | 01:19 AM
SacCityCorvette
Supporting Vendor
Hi bracketshark,
I think you and leadfoot4 might have a good point. There may also be cranks that are keyed. So we will incorporate the groove. Thanks guys you for your input. Being that we like to bring you the best products we can, we really like to listen to what have to say. Makes for a better product.
Thankyou,
Christian
Old May 3, 2013 | 07:07 AM
leadfoot4's Avatar
leadfoot4
Hi bracketshark,
Thankyou,
Christian
I'll have to check in with you in a few weeks, as I'm planning on installing a new harmonic balancer on my car within the next month or so, and your tool looks like a good thing to have. (I'm planning on "pinning" my crank with the ATI fixture)
Old May 3, 2013 | 12:07 PM
SacCityCorvette
Supporting Vendor
We have them ready to go with the groove for the pin.
Christian
Old May 3, 2013 | 06:01 PM
leadfoot4's Avatar
leadfoot4
Christian
What took so long???
Old May 3, 2013 | 06:09 PM
SacCityCorvette
Supporting Vendor
Old May 3, 2013 | 06:20 PM
leadfoot4's Avatar
leadfoot4
Order sent.......
Old May 3, 2013 | 06:32 PM
SacCityCorvette
Supporting Vendor
Thank you leadfoot4, we appreciate your business!
We'll get it right out to you!
To Timing cover measurement needed
Old May 4, 2013 | 09:08 PM
SacCityCorvette
Supporting Vendor
Here is a picture with the recomended groove for the pin.
Old May 8, 2013 | 02:56 PM
leadfoot4's Avatar
leadfoot4
Hey Guys!
I received the tool today....thanks!
Old May 9, 2013 | 12:59 PM
SacCityCorvette
Supporting Vendor
Hey Guys!
Thank you for your business!
