air conditioner not blowing cold, or even cool
Old Apr 30, 2013 | 07:06 PM
andy9743's Avatar
andy9743
Default air conditioner not blowing cold, or even cool
99 frc, manual controls on the hvac
well did a bit of research and i'm not sure where to go from here...blower works well but no cold air. no codes. compressor has a belt on it but doesn't seem to be "kicking on" like it does on my other ls engine. its just spinning. blows warm on both driver and pass side on both fresh and recerc modes.
check pressure on low side? add freon if needed? thoughts?
also of note i just had a cam/heads/intake put on the car. as far as i can remember a/c worked before this (car is still fairly new to me)
thanks guys
andy
Old Apr 30, 2013 | 08:02 PM
andy9743's Avatar
andy9743
after a bit more reading i tried the air again and felt both lines...both seem to be about the same temp, one was not COLD and the other hot like i read they are suppose to be.
Old May 1, 2013 | 10:52 AM
Corvette_Ed's Avatar
Corvette_Ed
I would suggest checking that compressor to se if it's working. If not, replace it, if so, you probably have a leak. Either way I'd start with the compressor.
Old May 1, 2013 | 11:53 AM
SaberD's Avatar
SaberD
if you aren't getting any codes, it's most likely the compressor clutch.
To air conditioner not blowing cold, or even cool
