The Loosening Gas Cap
Old May 1, 2013 | 05:19 PM
nmacdonald's Avatar
nmacdonald
Default The Loosening Gas Cap
I have a 99, stock C5 with 74,000 miles. After I first got it several months ago, there was an issue with the cars gas cap so I picked a new one up at the dealer. It has seemed to work just fine. However....we're on an extended road trip and I have noticed on the last few fill ups that the cap seems to come loose. Not to the point of fall off, but to the point where a half turn and it's off. After I fill up, I always turn it so it clicks three or four times before closing the fuel door yet it still seems to "come loose."
This could be absolutely normal and I just didn't notice it with the first gas cap or on my 97 when I had it. But thought I'd check in and see if anyone has any thoughts.
We're having a great trip.... NC down through the southern states to Houston, then up to the Panhandle of TX and on our way home in a few days.
Old May 1, 2013 | 07:53 PM
bobby777's Avatar
bobby777
It must be fine-as your CEL would come on-
Old May 2, 2013 | 09:33 AM
nmacdonald's Avatar
nmacdonald
Thanks, no problem with the CEL so I'm not gonna worry.
Old May 2, 2013 | 09:57 AM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
If you start throwing code 0442 or 0422 (I forget which one), then you'll know that it's causing problems. Until then I wouldn't worry about it.
Old May 2, 2013 | 06:57 PM
nmacdonald's Avatar
nmacdonald
To The Loosening Gas Cap
