Need solution for Code P0118 H C
Old May 2, 2013 | 12:08 PM
herbgriff's Avatar
herbgriff
Navigator
Default Need solution for Code P0118 H C
I installed a new water temp sensor with no change. DIC still shows P0118HC as before. (See my post Problems after LT Header install).
Old May 2, 2013 | 12:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Recommend inspecting the connector and the wires in that harness for damage.
The wires in the back of the connector are easily damaged and pulled out of the actual pin and can look attached. The sensor gets 5 VDC on one wire and the signal out is the other wire. Do you have the 5 VDC?
Read the other wire to ground and see if you get any resistance readings. Examine the female pins inside the harness connector and make sure that they are not damaged and spread apart.
Let us know what you find.
Bill
Old May 3, 2013 | 02:48 PM
herbgriff's Avatar
herbgriff
Navigator
Just checked wiring harness pins. No voltage or resistance. I guess I need to replace the wiring harness. Where does the other end hook up? You've been giving me great advise.
Old May 3, 2013 | 03:38 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BOTH wires go ALLLLLLLLLLLL the way to the PCM!
However,,,,,,,,,, look at the rear of the drivers side fuel rail. In OEM configuration, there is a BLACK Metal Bracket that the engine wiring harness bends around to go to the main engine harness. The point where it bends around the bracket can and sometimes does chafe thru and cause shorts and issues like you are seeing. Check there first. Untape the harness and follow the wires.
Old May 4, 2013 | 09:22 AM
Mickeyrx70's Avatar
Mickeyrx70
Old May 4, 2013 | 12:44 PM
herbgriff's Avatar
herbgriff
Navigator
Bill,
On driver side coil pack, both wires were pinched and broken under coil pack bracket below alt. Repaired breaks in wires. Voltage @ 5VDC. Started up. No codes or check engine warning. Both analog & digital water temp gauges work correctly. Thanks to you, problem solved. Thanks again.
Herb G.
To Need solution for Code P0118 H C
