Electronic Brake Control Module Delete
Old May 3, 2013 | 09:39 PM
elite_cyborg's Avatar
elite_cyborg
Default Electronic Brake Control Module Delete
has anyone done this? looking for information on how to get ride of this.
This is what im talking about.
Old May 3, 2013 | 10:17 PM
corvette77's Avatar
corvette77
Is yours throwing a code? It is an easy DIY fix. There is a great thread on here about how to fix it yourself.
Old May 3, 2013 | 10:22 PM
elite_cyborg
Yea it has been broken for the last year or so, mainly want to get rid of it to have more room for a turbo build
Old May 4, 2013 | 11:28 AM
lionelhutz's Avatar
lionelhutz
You remove it.
You connect the front lines together and rear lines together using splitter blocks.
You connect the splitter blocks to the master, putting an adjustable proportioning valve in the rear line.
Old May 4, 2013 | 04:27 PM
elite_cyborg
What do you think about this?
http://www.wilwood.com/MasterCylinde...emno=260-11179
Old May 6, 2013 | 12:23 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by lionelhutz
You remove it.
Any write ups?
Old May 6, 2013 | 12:56 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by All_Motor_C5LS6
Any write ups?
No. If you can fabricate brake lines you should be able to handle the job.
Old May 6, 2013 | 02:34 PM
elite_cyborg
This
Old May 6, 2013 | 02:45 PM
lionelhutz's Avatar
lionelhutz
That valve you linked looks like the right idea. I have no idea if the line sizes are right though and you'll still need a T for the rear lines in there somewhere. You'll have to find the line sizes or measure them and then pick the valve that matches the lines.
To Electronic Brake Control Module Delete
