M6 transmission removal question
Old May 6, 2013 | 12:19 PM
alextz's Avatar
alextz
Default M6 transmission removal question
I have seen the DIYs etc,
Can you remove the transmission/differential without taking the torque tube/clutch out?
In other words, if you were just working on the tranny, and clutch is fine, can you save work by disconnecting tranny from torque tube and leaving the torque tube/clutch attached to car?
thanks
Old May 6, 2013 | 12:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!! IMHO, that the best way to service your drive line. You need to remove the rear cradle and drop the differential and trans as a unit.
What do you need to do with the trans??
Bill
Old May 7, 2013 | 10:50 PM
alextz's Avatar
alextz
can you take out the tranny without removing the tunnel plate?
Old May 8, 2013 | 09:37 AM
feeder82's Avatar
feeder82
no you have to lower the torque tube slightly to get out the diff and trans
Old May 8, 2013 | 09:54 AM
lionelhutz's Avatar
lionelhutz
Yes, you can.
To M6 transmission removal question
