Successfully weld headers?
Old May 8, 2013 | 10:05 AM
WildWolf's Avatar
WildWolf
Default Successfully weld headers?
I believe I have a leaking FLP Header. Is it possible to successfully weld the header? If so, what type of welder should I look for?
Old May 8, 2013 | 10:24 AM
Kmcoldcars's Avatar
Kmcoldcars
I would assume the header can be welded with it in the car, depending on the location of the area that needs to be welded. My 1971 Buick Gran Sport Stage 1 had Kenne Bell headers on it, which wrap around the steering and need to be welded together after they were positioned on the car. When a crack developed in one of the header tubes, I took it to a local exhaust shop and they were able to weld it. Good luck.
Old May 8, 2013 | 12:47 PM
lionelhutz's Avatar
lionelhutz
Any decent welding shop should be able to weld stainless. Some exhaust shops should be able to do it too.
Old May 8, 2013 | 02:11 PM
Last C5's Avatar
Last C5
I've had several headers (broken air tubes) welded in the car. Shouldn't be a problem. Either TIG, preferred, or even a well set up MIG will work.
Old May 8, 2013 | 05:15 PM
GySgt1811's Avatar
GySgt1811
WW,
Was this the source of your intermittent exhaust "rumble ?"
Gunny John
To Successfully weld headers?
