tpms
Old May 9, 2013 | 12:59 PM
circlesport's Avatar
circlesport
Default tpms
Does anyone know if you can run tpms from a C6 on a C5?
I have C6 wheels and wondering if they would work.
Thanks for any info.
Old May 9, 2013 | 07:43 PM
circlesport
Thanks for the info.
Old May 21, 2013 | 07:04 PM
Ogopogo's Avatar
Ogopogo
I was wondering the same thing. Have an opportunity to get C6 wheels and tires from my neighbor.
What would be needed to make it work or is it just not technically possible ? Anything like changing early C5s to 2001+ tpms ?
Old May 22, 2013 | 01:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES YOU CAN UP-GRADE the EARLY C5 TPS to the LATE modle C5 TPS system. Its easy as contacting Gene Cully or Patrick at www.gmpartshouse.com and ordering his up-grade kit. You get new FOBs, New TPS's a and a New RFA module.
Here a few post that you need to accomplish the up grade:
- C5 Tire Pressure Monitor Sys Up-Grade 97-2000 to 2001 RFA System: http://forums.corvetteforum.com/c5-t...e-sensors.html , http://forums.corvetteforum.com/c5-t...aded-tpms.html
C6 TPS and FOBS will NOT work on any C5 and CAN NOT "easily" be adapted to work!
I guess if you spent enough cash, you could coble any upgrade to fit into a C5, but,, its not a tried or easy thing to do.
Old May 22, 2013 | 04:12 PM
Ogopogo's Avatar
Ogopogo
Thanks Bill, I sort of thought that might be the case.
I'll probably just put the C5 sensors in the C6 rims for now.
Old May 22, 2013 | 11:15 PM
circlesport
That's my plan as well.
To tpms
