G Tech Pro
Old Jun 22, 2002 | 09:01 AM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Default G Tech Pro
I finally got a chance to run my Coupe with my G Tech Pro.
A, straight, flat section of new Interstate with no traffic and a concrete
median barrier to keep those pesky Troopers approaching from the opposite direction from making a u-turn. :D
I had a 1/4 tank of gas and a 175 lb. passenger. Made 3 runs (all were within several tenths of each other)
Best times were: 0-60 = 5.03, 1/4 mi = 13.41 @ 108.5
I realize the mph reads high on the G Tech (due to the way it calculates mph in the 1/4 mi) so 103-104 mph is probably closer to an actual track timed mph reading, but the times should be pretty close to a track ET.
For a stock A4 with 175 lbs of passenger, I was happy with the results. It gives me a baseline for those inevitable, upcoming mods. :D
I realize this isn't Z06 territory but it's a lot faster than my last ride and it was a whole lot of fun. :yesnod:
Old Jun 22, 2002 | 11:29 PM
ambitin's Avatar
ambitin
Default Re: G Tech Pro (2k2C5)
Glad you had fun with it. I'm waiting for the next generation measurement-tools coming out by the end of this year.
Keep in mind that at 1/4 mile track, you might do better because generally you'll be running on a very well prepared and maintained surface whereas out on the street there is a lot of variability in the surface.
Lates,
Justin
Old Jun 29, 2002 | 07:09 PM
sandyg's Avatar
sandyg
Default Re: G Tech Pro (ambitin)
The new g tech pro meter is out. Summit and JC Whitney are shipping them See the string on the forum under c5 tech.
To G Tech Pro
