99 Dash Controls - Help Needed
Old May 13, 2013 | 04:36 PM
ster1ing's Avatar
ster1ing
Cruising
Default 99 Dash Controls - Help Needed
The buttons for different digital dash functions quit working (Item #1 pic) recently. Anyone have any suggestions about how to reset them?
Also, the passenger climate control know (Item #2 pic) doesn't seem to work. Any ideas?
Old May 13, 2013 | 05:55 PM
ster1ing's Avatar
ster1ing
Cruising
From reading other posts I understand that these buttons control the IPC. Here's a link that I found.
http://corvetteforum.shelor.net/Docs...d_Diagnostics/
Old May 14, 2013 | 12:16 PM
dadaroo's Avatar
dadaroo
Do the lights on the buttons work? Also, does the display at the bottom of the IPC display Corvette by Chevrolet at startup?
Old May 14, 2013 | 12:33 PM
ster1ing's Avatar
ster1ing
Cruising
I will check if the lights work or not this evening and the message when the key is first inserted.
Old May 17, 2013 | 12:31 AM
ster1ing's Avatar
ster1ing
Cruising
The lights on the buttons work, the readout first says "Corvette by Chevrolet", next it said door adjar so I shut the door. I started the car and the readout gave the mileage. I pressed the fuel button, the options button, and nothing happened.
Old May 18, 2013 | 09:39 AM
dadaroo's Avatar
dadaroo
My first though is that the unit is bad, or a connector issue. Unless someone else has some better idea, I think you will have to pull the unit.
To 99 Dash Controls - Help Needed
