Lost 1 valve keeper??
Old May 13, 2013 | 09:43 PM
TBH94's Avatar
TBH94
Default Lost 1 valve keeper??
In the middle of doing a cam swap and upgrading the valve springs and push rods.
While putting on one of the new springs, the tool popped off and shot one of the new valve keepers across my garage. I can't find it anywhere. To my knowledge, the keeper fits the valve size. So, my question is, can I just use two of the original keepers on the new springs? They seem to fit.
Has anyone run into this issue??
Old May 13, 2013 | 10:17 PM
DooDooBear1999's Avatar
DooDooBear1999
Do you mean the valve spring locks?
Old May 13, 2013 | 10:39 PM
bumble-z's Avatar
bumble-z
When I replaced my valve springs, I used the original ones.
I had purchased around six new one's, just in case I would loose some on the spring install.
I ended up using one or maybe two of the new ones.
No problems.
Old May 13, 2013 | 11:01 PM
StingrayRebel's Avatar
StingrayRebel
did you change the valves and retainers also or just the springs?... if you are reusing you oem retainers and valves then yes the factory lock will work... if you changed retainers you should find out the lock angle on them to make sure your factory ones will work because they may fit the groove in the valve but if the angle is different then your springs and retainers can still pop off... I would not put it back together until you find the one you lost or find the correct replacement... I had the same thing happen to me when I did mine, I ran a magnet all over my damn engine bay and an hour later I found it under the corner of one of my jackstands... it almost looked like someone put it there on purpose it was so well hidden
Old May 14, 2013 | 04:35 AM
vettenuts's Avatar
vettenuts
If the ones you are installing are not the OEM, who is the manufacturer or vendor where you got them? Many will shoot you a set of two in the mail real quickly when things like this occur. If you are not installing OEM, I personally would prefer to replace the lost one as long as you are sure it isn't inside the motor.
Old May 14, 2013 | 06:21 AM
TBH94's Avatar
TBH94
I am sure it is not in the motor. I have been unable to find the one I lost. I have sent an email to comp cams and am waiting to hear back.
I am replacing the springs and retainers. I guess the best thing to do at this point is get the correct replacement. Even if I have to buy a whole other set.
Thanks for the help
Old May 14, 2013 | 06:46 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Use grease on the locks, they will sit on the valve much better.
Seriously, it's the small details that often matter the most at the end of the day
HTH
Old May 14, 2013 | 11:56 AM
vettenuts's Avatar
vettenuts
Thanks for the help
If its from Comp it is likely a machined lock and stronger than stock. Wait for the replacement
Old May 14, 2013 | 08:52 PM
TBH94's Avatar
TBH94
Spent an hour and a half after work today and I am glad to report.....SUCCESS!! I finally found the little guy in the collector part of my header. Where the 4 pipes come together.
I also ordered a better spring compressor that will bolt to the head and do two springs at once. The other crank style kept popping off.
Thanks for the input. Much appreciated!
Old May 15, 2013 | 12:28 AM
StingrayRebel
glad you got it worked out, its all downhill from there
Old May 15, 2013 | 05:13 AM
vettenuts's Avatar
vettenuts
I hope you don't mean the claw type that grabs the springs.
Old May 15, 2013 | 09:49 PM
TBH94's Avatar
TBH94
No. I ordered the one that bolts to the head and screws down to compress 2 springs at a time. I was using the claw type that you screw down. That is the style that popped off and lost the keeper. It is also really hard to use close to the firewall.
http://www.summitracing.com/parts/tfs-90307/overview/
Hopefully this will make things easier.
Old May 16, 2013 | 04:38 AM
vettenuts's Avatar
vettenuts
Unfortunately the claw type can scratch the valve spring surface finish which can lead to premature failure of the valve spring. You may want to look them over very closely prior to running the car.
To Lost 1 valve keeper??
