Rear Rotating Noise while Coasting
NOW for the sob story: Left rear hub assembly failed during track time in Pueblo, CO. Hub (with lugs and wheel) broke away from bearing housing, and I limped back to pit, with the loose wheel and rotor being held laterally by the caliper. There was a lot of growling as the bearing housing tried to drive the separated hub, and traction control tried to help while limping back. Towed home, replaced both rear hubs, and resurfaced both rotors.
So, whatdya think? Could the posi clutches or something in the diff have gotten damaged? Could one or both CV's have gotten damaged? I hope I don't have a bad new Timken hub assembly, but that would be the cheap way out, wouldn't it.
thanks for your opinions,
Rich
For the rest of the readers, he also just had a new trans installed so his trans and diff are both very recently serviced.
