Differential Gears
If you pick up a complete diff, its not complicated, but a bit of work. If you're talking about replacing the ring and pinion in your existing diff, your going to need a little expertise and several other refresher items (seals and stuff) as well.
You will gain a tiny amount of maximum fuel economy, but loose acceleration at all times, and torque when on hills..Think of going southtbound on the I-5 out of Portland in the Terwillerger Curves, the long uphill..you might have to leave 4 th to keep the load in the cam range of the engine. With 3.15 it is is no sweat.
Yeah, I'm in the Portland area too!
M6 >R&P 3.42 >Final drive ratio
1st Gear 2.66:1 =9.0972:1
2nd Gear 1.78:1 =6.0876:1
3rd Gear 1.30:1 =4.4460:1
4th Gear 1.00:1 =3.4200:1
5th Gear 0.74:1 =2.5308:1
6th Gear 0.50:1 =1.7100:1
Reverse 2.90:1 =9.918:1
Z06/M12 >R&P 3.42 >Final drive ratio
1st Gear 2.97:1 =10.1574:1
2nd Gear 2.07:1 =7.0794:1
3rd Gear 1.43:1 =4.8906:1
5th Gear 0.84:1 =2.8728:1
6th Gear 0.56:1 =1.9152:1
Reverse 3.28:1 =11.2176:1
A4 >R&P 2.73 >Final drive ratio
1st Gear 3.06:1 =8.3538:1
2nd Gear 1.62:1 =4.4226:1
3rd Gear 1.00:1 =2.7300:1
4th Gear 0.70:1 =1.911:1
Reverse 2.29:1 = 6.2517:1
A4 Option >R&P 3.15 >Final drive ratio
1st Gear 3.06:1 =9.639:1
2nd Gear 1.62:1 =5.103:1
3rd Gear 1.00:1 =3.150:1
4th Gear 0.70:1 =2.205:1
Reverse 2.29:1 =7.2135:1
A4 CUSTOM with M6 or M12 differential
A4 >R&P 3.42 >Final drive ratio
1st Gear 3.06:1 =10.4652:1
2nd Gear 1.62:1 =5.5404:1
3rd Gear 1.00:1 =3.4200:1
4th Gear 0.70:1 =2.3940:1
Reverse 2.29:1 =7.8318:1
Of course, R&P is "Ring and Pinion"
Your current final drive ratio is 4th Gear 0.70:1 =2.205:1, if you went to the 'stock' A4 economy differential, it would be 4th Gear 0.70:1 =1.911:1 that is quite a big difference in actual feel of how a car responds to throttle.
P.S. Oregon native here too
Before I started modding the vert I was running 3:15s and it averaged a little over 31 at 75-85 on the road. I really doubt you will be happy with the difference in performance for the tiny bit of extra fuel mileage.
