80 mm maf housing
Old May 20, 2013 | 01:38 AM
yaknow's Avatar
yaknow
Default 80 mm maf housing
Anybody with an '97-2000 using one of these? Are they worth using? I"ve done heads and cam, vararam, headers and exhaust, LS6 intake, 36# injectors and high flow air bridge and tune ---
I did a search, and I know, I like pudding. Will I need to go back for a re tune?
Old May 20, 2013 | 02:04 AM
Ohyoufan's Avatar
Ohyoufan
I did this conversion on my old ws6 and while I didn't gain anything on the dyno (knew I wouldn't, it was purely for looks) but it sure does look a lot better than the pre 01 MAF's. The 01+ MAF have the IAT sensor built in so it cleans up the bay a little bit. The downside, you'll have to buy an adapter harness to make it work. You will also need a re-tune to download the MAF tables
