Yup, knew about the torque-to-yield, but even my C4 guru friends couldn't answer the righty tighty question. The outer belt groove had moved all the way to the inside belt groove, causing the serpentine belt to jump off the pulley.
I can't believe YouTube came to my aid. Used the starter to remove the pulley bolt. Watched which way the crank turned, and wedged the breaker and socket to a solid surface. Came out slicker than I thought. Just remember to explain twice to your wife that you just want her to bump the starter.
Good way to trash your crank snout. Our crank/balancers aren't keyed, and you run the risk of spinning the balancer on the crank using that method.
So now I have to ask, how do you plan on installing the new bolt?
Couple of people broke the block casting with this method, you got lucky. You might want to consult the service manual prior to installation as the number of wrecked crankshaft snouts due to improper installation at this point is too many to count.
