Current Technical Service Bulletins By Year
Old Jun 23, 2002 | 03:14 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Current Technical Service Bulletins By Year
2002
#99-01-39-004A Air Conditioning Odor (Install Kit) - (05/22/2001)
#01-03-10-009 Plastic Wheel Nut Covers Missing and/or Loose (Replace Missing Covers and Add Sealant to all Covers) - (11/01/2001)
#01-05-25-004A Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg (Handling) (repair/Reprogram ABS Module) - (11/15/2001)
#01-07-30-038 DTC P0757 Set, SES Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (11/27/2001)
#02-06-04-010 Erratic Fuel Gauge Reading (Reprogram the PCM) - (02/21/2002)
#02-06-04-015 Intermittent No Crank, No Start (Clean Battery Side Terminal Stripped Threads, Replace Battery Cable Bolt) - (03/08/2002)
#02-08-50-002 Driver Seat Movement During Acceleration and Braking (Replace Adjuster Assembly) - (03/13/2002)
#02-08-57-003 General Waterleak Guide - (04/30/2002)
#02-06-04-023 Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor) - (05/09/2002)
2001
#01-08-58-001 Windnoise Around B-Pillar (Add Sealer) - (01/29/2001)
#01-05-25-004 Yellow: Traction Control/Handling Lamp On, Drivers Info Center Displays Service Active Hndlg (Handling) (Repair/Reprogram ABS Module) - (03/19/2001)
#01-05-22-002 Incomplete Brake Pedal Return (Replace Vacuum Brake Booster) - (03/29/2001)
#01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors) - (05/02/2001)
#01-08-64-009 Door Rattle with Moderate to High Audio System Volume (Insulate Door Components) - (06/11/2001)
#01-08-67-003 Squeak From Rear of Convertible Top (Replace Protecotr Assembly) - (07/27/2001)
#01-06-01-023 Higher Than Expected Oil Consumption (Replace Rings) - (10/01/2001)
#02-06-04-001 Lack of Power Following a Wide Open Throttle 4-2 or 3-2 Downshift and Subsequent 2-3 Upshift (Reprogram PCM) - (01/08/2002)
#02-08-111-001 Paint Wear Through at Fifth Bow (Replace Seal) - (02/05/2002)
#02-06-01-021 Whistle Noise From Intake Manifold/Throttle Body (Replace Intake Manifold) - (05/22/2002)
2000
#99-08-45-005 Accessory Receptacle is Inoperative (Check Aftermarket Device Plug) - (11/08/1999)
#00-06-02-001 Engine Runs Hot, Overheats, Loss of Coolant (Polish Filler Neck/Replace Radiator Cap) - (01/05/2000)
#00-03-10-001 Low Tire Pressure Message on DIC, Slow Air Loss (Replace Wheel Assembly) - (02/02/2000)
#00-08-64-004 Window Motor Noisy/Inoperative (Replace Motor/Regulato) - (03/13/2000)
#00-06-05-002 Exhaust Boom at 1500 RPM (Install Spacers to Exhaust Hanger) - (05/05/2000)
#00-08-42-002 Tech - Left Headlamp Door Does Not Stay Closed - (05/30/2000)
#00-08-44-006A Power Antenna Not Working Properly/Inop (Replace Antenna O-Ring Assembly) - (07/21/2000)
#99-06-04-029A Intermittent Accessory Drive Rumble During Garage Shift (Install New Generator) - (11/29/2000)
#01-06-04-022 Inaccurate/Erratic Fuel Level Gage Readings (Install New Sensor, Strainer and/or RH Fuel Sender Assembly) - (03/16/2001)
#01-02-35-008 Electronic Steering Column Lock May Refuse to Operate - DIC Service Message Displayed (Update Column Lock Wiring, Install Revised Relay and/or Replace Electronic Column Lock) - (12/03/2001)
#01-07-30-023B Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body) - (03/22/2002)
1999
#87-65-10 NO START CONDITION NON-FUNC. PCM AFTER - (02/24/1998)
#83-17-04 DOOR HANDLES ON WHITE PAINTED VEHICLES TURNING YELLOW - (10/09/1998)
#43-17-01B BUMPS OR RUST COLORED SPOTS IN PAINT DUE TO RAIL/IRON DUST - (07/31/1998)
#99-06-01-007 Technical - Accessory Drive Squeak (Replace Idler Pulley) - (05/07/1999)
#99-07-29-001 Squeak Type Noise From Leather Shift Boot when Shifting Gears (Replace Boot) - (05/24/1999)
#99-08-50-010 Premature Wear of Leather Material on Bucket Seatback Bolster (Replace Cover) - (06/25/1999)
#99-08-49-008 Chime Sounds When Key is Removed from Ignition (Inspect/Replace Lock Cylinder) - (06/25/1999)
#99-07-30-013 Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy) - (07/27/1999)
#99-08-42-005 Loose or Missing Headlamp Door Bezel Plug (Install New Bezels and Plugs) - (08/02/1999)
#99-06-04-030 Hesitation, Sag, Stumble and/or Backfire on Acceleration (Reprogram PCM) - (08/16/1999)
#99-06-02-016 Engine Low Coolant Light Comes On (Inspect Rad. Surge Tank, Replace/Reposition) - (09/28/1999)
#99-06-04-052 Left Fuel Tank to Underbody Contact/Rattle Noise (Install Foam Insulator Pad) - (10/21/1999)
#00-07-30-022 No Reverse, Second Gear, or Fourth Gear (Replace the Reaction Sun Shell) - (11/10/2000)
1998
#87-61-13 BELT RUMBLE NOISE AT LOW IDLE SPEEDS (INSTALL - (02/18/1998)
#87-65-16 REDUCED ENG. POW. MESSAGE ALONG W/ PARTIC. PWRTRAIN - (03/24/1998)
#83-34-07 MUFFLED CLATTER TYPE NOISE COMING FROM CENTER OF PASS. - (03/27/1998)
#83-15-04 CLICKING NOISE COMING FROM FOLDING TOP - (04/08/1998)
#83-81-25 REAR WINDOW DEFOG. INOP (PLUG IN, REROUTE, - (04/08/1998)
#83-15-06 TONNEAU COVER MAKES NOISE WHEN GOING OVER BUMPS - (04/22/1998)
#23-50-05B REDUCING DISC BRAKE COME BACKS (NEW TOOL KIT & POLICY CHANGE) - (11/10/1997)
#33-17-01A PAINT PEELING FROM MUFFLER (NEW REPAIR PAINT AVAILABLE) - (12/01/1997)
#73-15-12A LOOSE LOWER FRONT FASCIA VALANCE PANELS - (07/14/1998)
#83-15-05 DOOR GLASS RATTLE (INSTALL INSULATOR) - (04/24/1998)
#83-15-07 HISS TYPE NOISE COMING FROM WEATHERSTRIP WHEN CLOSING - (05/05/1998)
#83-15-08 WATERLEAK ABOVE DOOR GLASS (RESEAL BLOWOUT CLIP) - (05/19/1998)
#83-15-11 DISCOLORATION OR STAINING OF PLENUM (COWL) AIR INLET SCREEN - (06/03/1998)
#83-15-13 FRONT FENDER TO DOOR FIT/ APPEARANCE (INSTALL RETAINER) - (07/17/1998)
#83-62-11 ENG. LOW COOLANT LIGHT COMING ON WHEN PARKED DOWNHILL OR ON - (07/28/1998)
#83-63-10 FUEL PUMP NOISE COMING FROM PUMP/TANK - (04/28/1998)
#83-66-07 EXHAUST MUFFLER INSULLATOR RUMBLE NOISE (INSTALL NEW - (07/17/1998)
#83-82-07 LOOSE OR MISSING HEADLAMP DOOR BEZEL PLUG - (04/01/1998)
#83-90-14 INOP. REMOTE KEYLESS ENTRY SYSTEM AND/OR TIRE PRES. - (08/28/1998)
#99-08-52-002 RKE and/or Low Tire Pressure Monitoring System Inop (Replace RKE Module) - (04/20/1999)
1997
#73-10-55 WATER DRIPS INTO REAR COMPARTMENT AFTER HATCH/GLASS - (06/13/1997)
#73-10-58 HATCH WILL NOT POP UP WHEN ACTIVATED IN COLD WEATHER - (09/11/1997)
#73-83-22 ERRATIC FUEL GAUGE READINGS (REPAIR PINCH - (09/25/1997)
#83-11-10 BLOWER MOTOR - RUN ON WHEN IGNITION IS OFF - (01/27/1998)
#83-81-24 VARIOUS DRIVEABILITY CONDITIONS - (03/03/1998)
#43-64-07A LOW VOLTAGE READING OR DIM LIGHTS AT IDLE - (01/01/1997)
Old Jun 23, 2002 | 04:25 AM
pkmoose's Avatar
pkmoose
Default Re: Current Technical Service Bulletins By Year (kewlbrz)
great info :cheers:
Old Jun 23, 2002 | 10:34 AM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: Current Technical Service Bulletins By Year (pkmoose)
Thanks for the info. Does anyone know if the Dealerships cover TSB's when the car is out of factory warranty? I do have an aftermarket one but would rather try and get Chevy to pay for it.
Old Jun 23, 2002 | 10:48 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Current Technical Service Bulletins By Year (MY1Fast99C5)
As a "rule of thumb",GM wont cover something that is out of warranty if you have an extended warranty...
Old Jun 23, 2002 | 11:11 AM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
kewlbrz,
Wow - thanks.
The lists clearly show the numerous problems of the C5 for many years. It is a shame that it has taken Chevrolet so many years to determine a "fix" for the numerous defects.
1999 White C5 Coupe
Old Jun 23, 2002 | 11:13 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Current Technical Service Bulletins By Year (1999 White C5 Coupe)
kewlbrz,
Wow - thanks.
1999 White C5 Coupe
no kidding....thanks Shawn :cool: :cheers:
Old Jun 23, 2002 | 11:26 AM
Slammed Vette's Avatar
Slammed Vette
Default Re: Current Technical Service Bulletins By Year (C-5 TECH)
What if you already brought it in under warranty and they said there was no fix for the problem at that time???????
Old Jun 23, 2002 | 12:28 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Current Technical Service Bulletins By Year (Slammed Vette)
"What if you already brought it in under warranty and they said there was no fix for the problem at that time???????"
The important key here is that you would have a documented history while under warranty,and if a usless aftermarket warranty company wont pick up the tab,GM may offer some assistance...Just one more reason to have GMPP as opposed to other aftermarket warranties :yesnod:
Old Jun 23, 2002 | 12:37 PM
Slammed Vette
I had a problem with my top wearing the tonneau and sqweaking when the top is folded.Also speaker rattle in passenger door.They did their fix on the door,but it still makes noise and they said there was no fix for the top!!!!!This is why I would never recomend this dealer to anyone!!!!!Do I have any recourse?
Old Jun 23, 2002 | 01:20 PM
carpe dm's Avatar
carpe dm
Really "kewl"..... Thanks. :D
Old Jun 24, 2002 | 02:11 PM
MagRed2002's Avatar
MagRed2002
Default Re: Current Technical Service Bulletins By Year (carpe dm)
Hey "Slammed Vette", it appears as though your Cardboard Box is somewhere in or near Chicago. Which dealership did you have problems with? Is there one or more Chicago area dealerships that you recommend for service? I've taken mine to Bill Kay, but only for very routine stuff to this point.
Old Jun 25, 2002 | 05:32 PM
Slammed Vette
Default Re: Current Technical Service Bulletins By Year (MagRed2002)
The dealer I was talking about was Bill Kay!!!I wouldn't recomend them to my worst enemy!!!!!If you have ANYwarranty work I would highly recomend Jason @ Team Chevy!!!!!!!I wouldn't let Bill Kay change the oil On my Hyundai work beater!!!!!!If you want any after market work done come see us at The Vette Wrench!!!!
To Current Technical Service Bulletins By Year
