Ok, first of all for the folks who like to tell people "search is their friend" and "this has been discussed a hundred times", I know that. I had the crank pulley replaced and since then I have had a chirp from the from of the motor that I can't seem to fix. I have done the following:
1. Replaced both belts with gatorbacks
2. Replace all tensioner and idler pulleys
The only thing I haven't done is physically check pulley alignment, however there is no visible misalignment. So, the question I have is:
Can the crank pulley be put on such that it is to far or not far enough on the crank leading to misalignment with the other pulleys?
There was absolutely no chirp problem before the crank pulley replacement.
The chirp is rpm sensitive. At idle no chirp, above about 1000 rpm chirp starts and gets louder until one reaches the maximum rpm of the pulley system. Chirp moves higher up the rpm range as the engine temperature increases. At about 194 F or so, the chirp is above 2000 rpm.
Any suggestions intended to be helpful are greatly appreciated.
Remove the alternator belt and listen again. This would help isolate the source. I have read some members moving the AC compressor around on the mounting bolts slightly. Check the AC clutch bearing. The alternator itself can also be a source.
Checked pulley alignment. There is approximately a 1 mm difference between the alternator pulley and the PS pulley. The PS pulley approximately 1 mm closer to the motor. Not much there. The other pulleys are closer if not exactly aligned.
No certain that small of a misalignment would have an impact. Still pondering.
I always say remove both belts and start the car....
squeak = problem
no squeak reinstall serp belt only.....start car...if you get the noise you have eliminated the AC pulleys if no noise reinstall AC belt and check again...pain in the ***
Removed the accessory belt and chirp was gone. So, AC belt and pulleys are fine. Removed accessory tensioner and idler pulleys, check for play, wear, etc. They were ok. Checked alternator and PS pulley no apparent wear. Replaced belt, chirp back. Dripped small amount of water onto belt while running, chirp went away until water dried up. So, appears to be belt issue, either belt compound or pulley alignment. Have ordered another belt, in that, I don't believe a misalignment of as little as 0.5 to 1 mm could be the cause. More to come late next week after I install the new belt.
Danny
Maybe clean the pulleys before installing the new belt. Brake cleaner and wire brush?
Mine has driven me nuts. I'm going to buy an alignment laser and see what it tells me. Maybe we should all chip in a few bucks each and share it. With all the belt noise problems forum members have we could keep one out in rotation. Members not in on the purchase could use it for a 5 or 10 dollar donation to Vettes for Vets. Stupid idea?
fix the crank pulley install. Are the grooves running straight on the pulley when the belt is off?
Was the crank installed with a arp bolt?
Crank pulley appears to be running straight. It would seem if the crank pulley was the problem the chirp would be present even with the accessory belt off because the AC belt also runs off the crank pulley. So, I don't believe the crank pulley is the cause. Didn't use an ARP bolt, but, did check to ensure the bolt had not backed out after installation. No problem there. So, back to belt compound as the most likely cause. Should have the gatorback later this week and will see if that results in a solution.
Interesting find in my research on belt noise is the use of talcum powder to stop the noise, at least for a few hundred miles. A little on the belt works great. Who would have thought of that.
I have use a bar of soap to clean the inside of the belt and it's worked before. Just be careful and put the bar slightly on the inside while its running. This will help clean the pulley grooves too
Danny
What bolt did you use? Not the same one i hope and if you did not use an arp bolt did you follow the correct torque procedure? Using an arp bolt makes it easier. You only have to torque once.
With out the belt on it there will not be tension on the pulley so no noise. The new belt may stop the sqwak for a bit but due to stating the problem started right after the dampner change it seems to be the spot i would double check.
Wire brush the crank pulley grooves.
I know, I know, "They look OK", but do it anyway. You'd be surprised. Even a little sand/grit/debris can get compacted into the groves and cause the belt to run a bit too high.
PITA? Yes. Do it anyway. Try to get all the around if you can.
Thanks for the suggestions, guys. I did clean/brush the grooved pulleys, all the way around. the crank pulley bolt was a new stock one and was installed via the GM procedure by the corvette shop that I use. I checked the crank pulley bolt for any signs of backing out and found no indication of that happening.
I replaced the belt last night with a gatorback and the chirp is gone. We'll see if it stays that way.
Gatorback is a good choice, if the noise surfaces again try some toothpaste (yep) on the pulley surfaces of the belt
Toothpaste, really. Interesting. First talcum powder now toothpaste. How long does the effects from the toothpaste last? The talcum powder lasts a couple hundred miles, less if it wet outside.
Danny
Just use plain white toothpaste, the abrasives it contains do a good job of polishing the surfaces of the pulleys and belt and the effect is pretty much permanent as long as your belt doesn't start slipping and glaze them up.
Well, no joy. Still chirping. Have replaced both belts with gatorbacks. Have replaced ac idler and tension pullies. The chirping occurs when engine temperature is below ~200 F. Above 200 F there is no chirp. Only chirps when accessory belt is on, so chirp is not from ac belt system. Chirp goes away when I put talcum powder or water onto accessory belt. So, I am assuming the cause of the chirp is alignment at this point rather than the accessory idler or tension pullies because the chirp goes away when putting talcum powder or water on the belt surface....? Is my logic sound on this?
By the way, I used some toothpaste and it did stop the chirp for a day or so, but, the chirp did come back.
