Starting Problem
Old May 26, 2013 | 09:58 AM
STARCRAFT's Avatar
STARCRAFT
3rd Gear
Default Starting Problem
HI GUYS..... I AM NEW TO THE FORUM AND HAVE A 1964 CON. AND A 2000 TAGRA I RECENTLY HAD MY BATTERY DIE ON THE C-5 AND NOW IT WANTS TO PLAY GAMES. IT STARTED UP RIGHT AWAY THEN TURNED OFF WHILE I WAS DRIVING AND DID WANT TO START BACK UP, IT DID AFTER A WHILE. I WENT TO THE OWNERS MANUAL AND IT HAD NOTHING ABOUT THIS PROBLEM. I TRIED THE SECOND KEY THINKING IT MIGHT BE THE RESISTOR TO NO AVAIL. I CAN WORK ON ENGINES BUT THESE NEW ELECTRONIC GIZMOS DRIVE ME CRAZY. I NEVER HAVE HAD THIS PROBLEM BEFORE. I WAS THINKING SOMEONE ELSE MAY HAVE HAD THE SAME PROBLEM AFTER A BATTERY CHANGE. THANKS IN ADVANCE !
Old May 26, 2013 | 10:36 AM
STARCRAFT's Avatar
STARCRAFT
3rd Gear
I have no codes on the car. If you turn the key on and off several times the display comes back and it starts up.
Old May 26, 2013 | 11:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,, You could very well have an issue with youre ignition switch. Service it and see if that solves the problem. Hey,,,,,, Its FREE.
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Let us know how you make out.
bc
Old May 26, 2013 | 10:38 PM
STARCRAFT's Avatar
STARCRAFT
3rd Gear
Thanks Bill... I will try this tomorrow the car has 120K so I am almost positive this is the issue. I will let you know.
To Starting Problem
