side markers
Old May 26, 2013 | 03:48 PM
riverrat68's Avatar
riverrat68
Default side markers
Have you guys replaced the side markers? I reached up under the fender and the bulbs are there, but I thought there were nuts on the studs?
I am beginning to think a previous owner might have glued mine on..
Old May 26, 2013 | 05:21 PM
LoneStarFRC's Avatar
LoneStarFRC
Default PAL nuts
Old May 26, 2013 | 05:40 PM
riverrat68's Avatar
riverrat68
Thanks, I thought that was what was missing. Thanks, I will get to the gm dealer on Tues.
Jer
Old May 26, 2013 | 06:22 PM
LoneStarFRC
Jer
As with all PAL nuts, they cut their own threads in the plastic studs on the backside of the marker when you screw them on. Easy does it when snugging them down.
Check with your local AP store or hardware store for these nuts I have seen them available there before. Dealers will rape you on prices. If the studs are broken off, maybe that's why someone tried glue or double-sided tape.
If you need a replacement light, check with Marc at Vettenuts.com. They usually have good clean used C5 parts at reasonable cost (615-896-6100). I've also seen them on the big auction site. Many come with the nuts.
Btw, easy access to these is through the outside tail light opening.
Old May 26, 2013 | 07:34 PM
riverrat68's Avatar
riverrat68
Thanks a bunch
Old May 28, 2013 | 10:20 PM
Rex99Coupe's Avatar
Rex99Coupe
First set I bought at O Reilly rounded off very easy. Napa had the better ones.
To side markers
