Engine stalls when coming to stop.
Old May 27, 2013 | 05:05 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Default Engine stalls when coming to stop.
Starts without a problem, idles fine. After driving a few blocks when coming to a stop the RPMS drop to 400, sometimes bounces back mostly stalls. Restarts with out a problem. And idles at 650 ... take off and at next signal will stall again.
Can't find any air leaks around the intake ... what am I missing???.
No codes show up.
Old May 27, 2013 | 07:22 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
No ... don't have the gauges.
Old May 27, 2013 | 07:34 PM
Rob Petyo's Avatar
Rob Petyo
sounds like it needs AIR - did you check for leaks?
Old May 27, 2013 | 07:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most of the time when this happens, Its a vacuum leak.. Most of the vacuum leaks are caused by cracked/deteriorated rubber fittings OR a dirty fouled MAF.
Remove the entire air bridge / air filter assembly and clean the MAF will MAF cleaner.
Follow the PCV lines around and behind the intake manifold and make sure that the rubber and Nylon fittings are nor deteriorated or cracked.
BC
Old May 27, 2013 | 08:20 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
BC
Bill is there a shop diagram of the vacuum lines? I have the shop manuals but I can seem to find all the lines.
Old May 27, 2013 | 10:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here are the PCV diagrams for both LS1 and LS6
LS6
LS1
Old May 28, 2013 | 12:06 AM
jochumr's Avatar
jochumr
St. Jude Donor '10
Thanks Bill .... I just found them in the service manual ... didn't realize it.
Old May 28, 2013 | 06:02 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Cleaned the MAF , checked for leaks and found one .. also noticed the throttle bottle was very dirty .. I think that was the real problem the paddle was sticking and sluggish ... clean it with the MAF cleaner and it purrs like a big cat now!
Old May 28, 2013 | 06:04 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
this pic was after the second cleaning .. did another and it got rid of the deposits along the edges.
Old May 28, 2013 | 11:01 PM
Mojointn's Avatar
Mojointn
Have you test drove the car yet and did it fix the problem?
Old May 28, 2013 | 11:35 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Just got back ... drove it for about 30 min in stop and go traffic .. idled just like its suppose too, no problem with stalling of rpm falling off.
To Engine stalls when coming to stop.
